Fan turned on => high pitched squeaking noise
Old Jan 1, 2005 | 01:01 PM
MaxxAddict's Avatar
Sounds as if the fans behind the vents need to be re-oiled. How about spraying some WD-40 on them? Worried about stinking up the car, though. Obviously, I'd probly have to pull out the vent covers.
Old Jan 1, 2005 | 01:03 PM
Nismotic's Avatar
Always sunny in philly
Same problem here. bump for the answer.
Old Jan 1, 2005 | 09:43 PM
MaxxAddict's Avatar
bump bump....
Old Jan 2, 2005 | 01:59 PM
blkhawk500's Avatar
ditto ....bump
Old Jan 2, 2005 | 04:05 PM
UncleMax98's Avatar
Most likely is a bad blower motor. The symptom is noise at low fan speed, loudest at speed 1. Noise typically goes away at speed 3 or 4. If fan is left at speed 4 for about 15 - 30 seconds, then no more noise (for a while), even if fan speed is set back to speed 1 or 2. Noise is also louder in recirculated mode.
The only fix is a new blower motor. Nissan has a TSB to put a plastic cover on the motor to reduce the noise. Don't waste your time with the TSB. It does not help at all.
Note: I took the blower motor apart to reoil it. Did not help with the noise.
Old Jan 2, 2005 | 09:01 PM
MaxxAddict's Avatar
how much for parts and labor to get that fixed??
Old Jan 3, 2005 | 06:09 AM
rome06's Avatar
Same thing happened to me....ended up being the belt needed to be tightened up a little bit
Old Jan 3, 2005 | 08:44 AM
UncleMax98's Avatar
Nissan OEM part is about $130 + $13 shipping (www.nissanparts.cc). Very easy to install yourself, about 30 minutes.
Old Jan 4, 2005 | 12:44 PM
cam_honestiam's Avatar
Same problem here. I took it apart, re-oiled: nothing. I can't justify the $$ for a squeak, though. I tried packing foam around it, etc. but to no avail...
captchaos
Mar 15, 2016 12:18 PM
alahjahwan09
18
Sep 21, 2015 09:12 PM
LtLeary
Sep 14, 2015 12:33 PM
Justin Kroll
Sep 2, 2015 11:06 AM
