Quietest cat back system???
Old Jan 1, 2005 | 06:28 PM
blackmaximvs's Avatar
What is the quietest cat back system out there that will still give a nice performance gain? Or are they all about the same?
Old Jan 1, 2005 | 06:36 PM
jdm71488's Avatar
they are all the same performance wise pretty much, muffler has about 1-2hp... as long as pipe diameter is the same, you are getting the same thing. for 95-96 it was the apexi, but thats no longer made. and you could get a sp2, which i heard is quiet, but i like my dynomax... BIG oval can...
Old Jan 1, 2005 | 06:39 PM
TN98MAXSE's Avatar
quiet
I took the warpspeed b and threw a obx muffler on it and the mufflers wide and its a low deep tone.
Old Jan 1, 2005 | 06:44 PM
maximabebe's Avatar
GREDDY SP2 has a nice deep rumble....almost unnoticeable at idle. Sounds really nice at WOT. Just my 2 cents. Heres a backshot:
Old Jan 1, 2005 | 06:52 PM
ScarfaceTHX's Avatar
If you don't want quiet, do not get a magnaflow muffler!
I have a WSP Y-Pipe, Budget SS 2.5" B-Pipe with Magnaflow Resonator, Custom 2.5" pipe to Magnaflow 14827 SS Muffler.
Sounds clips, pics, vids: http://www.v6atlanta.com/max_vids/magnaflow/
Old Jan 1, 2005 | 07:32 PM
Irish's Avatar
This is a democracy
so scarface even with the resonator yours is loud?
Old Jan 1, 2005 | 10:50 PM
michaelnyden's Avatar
try the warpspeed super-quiet catback system...call them up and ask for comparative decibel reading comparing greddy, mangaflow, dynomax... with their's....
Old Jan 1, 2005 | 10:59 PM
Nismotic's Avatar
Always sunny in philly
wsp's catback system's fitment is crap.
Old Jan 1, 2005 | 11:37 PM
Taken2DaMax's Avatar
try going with the new apexi' WS2...if it's anything like the first World Sport then it will be quiet.
Old Jan 2, 2005 | 12:43 AM
the fitment is only crap cause you read a review a member on here which took it to a shop which screwed up the install completely and put a pipe on backwards...!!! if installed by a good shop, you should have no problems! but it is by far the quietest according to several decibel readings (just make sure you opt for the resonated b pipe and no straight pipe for the quietest and least ricey sound possible)...of course it won't be all stainless steel shiny like other brands...but it's half the cost...also, you do get to choose from 6 different tips they weld on I believe...which is cool
Old Jan 2, 2005 | 01:03 AM
Nismotic's Avatar
i was really damn close to purchasing this, but i read from jdm and a few others that the fitment isn't great. Also, he stated that it may be "too" quiet...
Old Jan 2, 2005 | 03:51 AM
VQdriver's Avatar
scarface. that exhaust looks great. who made the axle back? how do you like the sound level while cruising versus WOT? how does it sound with the AC on and the car full of people? are you lowered and if you are, does the rear suspension beam hit the budget midpipe when you hit hard bumps? i'm looking to further refine my setup. personally, i would have the shop weld the muffler so the tip only sticks out 1 or 2mm from the bumper. looks great though. thanks.
Old Jan 2, 2005 | 02:35 PM
^^^bump^^^
Old Jan 3, 2005 | 06:38 AM
Max96GLE's Avatar
To have a quiet ride, I would keep everything stock. The engine is very quiet from inside. Meeeeeeeeee like!!!!!!!!!
Old Jan 3, 2005 | 12:52 PM
jdm71488's Avatar
look... mufflers can really make or break how your exhaust sounds... but yet it only yields about 1-2hp... so keep your stock one...
the major gain is basically from the b-pipe and a larger diameter... you can pick up an aftermarket from budget (lss) or either cattman as others do, bolt it on and still recieve the same gains as you would with a rear section added as well...
that way, it won't be as loud, but you still get power... and it's cheaper...
Old Jan 3, 2005 | 12:59 PM
Y2KSESteve's Avatar
IMO Cattman is the quietest and I've heard quite a few setups.
Old Jan 3, 2005 | 01:29 PM
AntiVelvet's Avatar
Stock '95-99 suck. Go with stock 2000-up Variable flow is the way to go.
Old Jan 3, 2005 | 04:30 PM
I didnt see the questions. sorry
Yeah - it's really loud even with resonator. Cruising is loud. WOT is louder. Either way, you cannot miss it. Grand Mufflers in Marietta, Georgia did all the work. Car is not lowered. B-pipe might be hitting something... if it is, I can't say for sure, and it's not noticeable except for hard left turns. I told them to mount the tip as flush as possible. It barely sticks out from the bumper when looking down, and it's hard to spot unless you are right behind it.
The tone is great. The car is loud at any RPM. That can be good or bad. I miss driving in stealth mode, however it is cool to barely touch the gas and see people in traffic turning their heads. I pity the fool that orders an unresonated pipe + straight through muffler... that crap has to be loud.
Old Jan 3, 2005 | 04:37 PM
maxspeed96CT's Avatar
The original VQ...
i had y-pipe with a resonated b-pipe and stock muffler. it sounded like crap on a bad day!
Go with a 2k2 muffler (and cut the bumper). Thats prolly what im going to go with sence its quit but has a nice sound at WOT.
im kinda iffy about the warpspeed catback. I had 2 flex sections break in a 6 month period on my warpspeed y-pipe .
Old Jan 3, 2005 | 05:00 PM
jdm71488's Avatar
i got their catback, fitment wasn't all that great, and it's just basically a dynomax super turbo clone, so pick up one of those for $50, and have a resonated b-pipe made, if you don't already have one...
Old Jan 3, 2005 | 05:29 PM
Toolrocks's Avatar
I've got the WSP setup and when I first got it, I loved it. Now, about a year later, I've noticed it sounds very ricey. Inside the car it sounds fine, however, outside is a different story. It's raspy at 3.5 up regardless of how hard you're on it. I'm getting a 5th gen muffler. I'm sick and tired of fooling w/ my exhaust. I should say though, I do love the butt-dyno results currently but the noise has gotta go. Yes, it's 2.5 throughout and resonated w/ turboclone muffler. One other thing, I'm a 5 speed and when I let off the gas and coast in a gear it really sounds horrible. I assume autos sound better since the car is always in gear. Hope that makes sense.
Old Jan 3, 2005 | 06:04 PM
The original VQ...
i know the sound. I had a y-pipe and b-pipe and stockmufler and it sound nice in the car, then when my buddies told me it sounds like a 2 cylinder car i heard it from the out side and was sad...
Old Jan 3, 2005 | 08:39 PM
big_al's Avatar
Does anyone have the warpspeed catback with the "quiet" muffler?
How does it sound?
Old Jan 3, 2005 | 08:54 PM
jdm71488's Avatar
How does it sound?
i do... sounds really nice... very subtle, but noticable. not ricey, not raspy... i wouldn't buy from them though, bad shipping times...
the muffler is a dynomax super turbo clone, so you could just get that and have the same thing, faster, and cheaper.
Old Jan 3, 2005 | 09:01 PM
optimus310's Avatar
I think SP2 is the quietest one, but the Cattman sounds so Sexy
Old Jan 3, 2005 | 09:43 PM
gsmith795's Avatar
i've heard many good things about the sp2. too bad they dont make them for 98
Old Jan 3, 2005 | 09:54 PM
Nismotic's Avatar
Yes they do. greddy sp2 is now made for the 97-99. also, the 95-96 version can be made to fit the 97-99
Old Jan 3, 2005 | 10:26 PM
Maxima99SE's Avatar
will fly for food
my magnaflow is quiet
but i'm not full cat back.... I've got WSP Y with Magnaflow 14827
Old Jan 3, 2005 | 11:33 PM
I have the "quiet" clone muffler....from WSP along with their y pipe and metallic high flow cat, with a resonated b pipe....quietest maxima setup I have ever heard and I have heard all the setups...the closest in quiet I have heard is the Apexi WS series actually which I don't believe they make anymore...I have even hear the new SP2 on a maxima in person...sounds much better than the SP1 but still too ricey for me!...which makes me love my WSP quiet muffler setup even more (but that's the case everytime I hear another exhaust setup on a maxima--makes me love my WSP setup even more...very subtle sound...very quiet...very manly, aggressive tone in cabin...haven't really heard it outside that much...wish I had a camera that took good video...otherwise I would record some clips for you guys...)....no rice/raspiness here!!!
Old Jan 4, 2005 | 02:53 AM
VQdriver's Avatar
i think i still like the borla muffler better. i think it has the deepest tone. my motor sounds like a V8 from the outside. no raspiness at all. so far this is the only muffler that doesn't sound like the others. i'm willing to bet a bigger, longer straight through resonator on the budget midpipe combined with a bigger borla pro XL muffler will be the ultimate. probably still too loud for the people who want a quiet setup though.
Old Jan 4, 2005 | 04:01 AM
happyricefob's Avatar
V^___^V
magnaflow SS muffler
JRod28
Dec 29, 2023 09:56 PM
Ben2003GLE
31
Jul 17, 2016 08:13 AM
hot04
Aug 24, 2015 07:07 AM
sonic7
Aug 20, 2015 12:23 PM
MikesChevelle
Aug 19, 2015 07:19 AM
