Starting problem..?
Old Jan 1, 2005 | 06:52 PM
tranz's Avatar
Starting problem..?
i didnt pull any codes, but you know the deal, almost everyday in the morning or if the car has been standing long enough i have to cold start it,(rev it up to start) so i went to Shell just to see what was going on they said theres a problem with the MAF, i dont know how serious this is or how costly it will be someone help?
Old Jan 1, 2005 | 06:57 PM
2 Da Max's Avatar
go get two dollars and get some throttle body cleaner. sam shiet happened to me. it gave me better idle when the motor is cold and better throttle response.clean around the tb the butterfly plate and behind the butterfly. check out mtorrvate.ca
Old Jan 5, 2005 | 12:34 AM
cyjad's Avatar
I think I'm having the same problem. When I have to cold start the car, I have to slightly pump the gas pedal to get the engine to continue run. Otherwise, the engine will just die. After I get it started it idles and revs just fine and drives just fine. Also, if I warm start it, I don't have to press the gas at all.
I wouldn't think this is related to the MAF.
I think it might be the throttle body, idle air control, etc.
Let me know if cleaning the throttle body did the job.
Old Jan 5, 2005 | 04:26 AM
chiwchan's Avatar
Cleaning the idle air control valve will fix that. I just did this the other day.
Old Jan 5, 2005 | 12:47 PM
SUM41GIRLIE's Avatar
WoW!!!!! thats exactly what is going on with my car, the other day it threw code 0103 engine coolant temperature sensor, I took it down to the shop but they said the sensor was working fine, then after that my car started dying on cold start unless reving the engine till it gets warm. As we speak my car is in the shop to diagnose problem and to fix it. I will let you know what they come up with!
Old Jan 5, 2005 | 11:31 PM
cyjad's Avatar
Well, I did a cleaning of the throttle body and I think that fixed the problem for now. The car started right up with having to give any additional gas. yipee.
Does anyone know how that crap builds up right in front of and around the butterfly in the throttle body? I thought that only clean filtered air is flowing into the throttle body. So, where does that black, carbon-like stuff come from?
The black gunk I was cleaning was immediately upstream of the butterfly.
Isn't the throttle body upstream of the pcv valve, the idle air control valve, and everything else that might introduce unclean air into the intake system? The only things upstream of the throttle body is the MAF, and air filter, right?
just curious.
anyone?
Old Jan 5, 2005 | 11:42 PM
Oblongshapes's Avatar
hmm, not what im having....
My car, i go to crank it and nothing, like theres a dead battery, but it isnt, then i try it a couple more times and it finally starts....
I replaced the alternator, i think maybe the belts too tight... i dunno
Old Jan 5, 2005 | 11:44 PM
Ant96GLE's Avatar
Yea seriously clean your throttle body... if not check your crank and cam sensors, if they are dirty they will cause your car to have hard starting.
Yes cyjad, the only thing upstream of the TB is the midpipe/resonator then MAF
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
Maxxx10
Sep 13, 2015 03:16 PM
trungg86
Sep 4, 2015 04:58 AM
