Do I need to replace my MT fluid for the 120k service?
Old Jan 2, 2005 | 11:55 AM
mb1's Avatar
mb1
If I have the synthetic?
also where is the cheapest place for the sparkplugs?
Old Jan 2, 2005 | 01:48 PM
BigLou93SE's Avatar
ngk coppers are only $1.50 each -- any auto part store
Old Jan 2, 2005 | 05:02 PM
mb1's Avatar
mb1
mmm...id rather take the stock platinums.
Old Jan 2, 2005 | 05:04 PM
p00tan6's Avatar
coppers are cheaper, spark better and you can change them out like 6 times with the price you pay for platinum.
Old Jan 2, 2005 | 05:07 PM
bill927's Avatar
I use the copper plugs but many prefer the platinum. As far as the manual trans, some say Redline, some say Amsoil. I used Amsoil, I like it a lot. It feels much better than standard oil. You'll need 4.5 to 5 quarts. I pulled the reverse switch to drain mine. If you do the same thing be careful with it, it can break, it's plastic. ONLY USE GL-4, NOT GL-5. Several write ups and my research suggest GL-4 ONLY. Amsoil does have it, they call it marine lube or something now but they do still have it.
Old Jan 2, 2005 | 05:14 PM
twill's Avatar
no kidding on the be careful with the reverse switch... I broke mine and had to replace it when trying to drain my tranny.
ouch.
Old Jan 2, 2005 | 05:26 PM
bill927's Avatar
Oh, and don't force the switch back in. It has an O-ring on it, make sure it stays in place. When you remove the switch the oil comes out in a hurry. Have a big pan handy. By the way. I think a gallon bucket is all they sell the amsoil in. It's around 30 bucks. Redline may sell quarts, not sure. Ask around about the pros and cons of each brand. If I remember correctly the redline works better in cold weather but the amsoil gives better wear resistance. That's what I read somewhere but you may want to look into it, I may be wrong. I'm sure a good synthetic GL-4 is better than non synthetic.
Old Jan 2, 2005 | 06:06 PM
mb1's Avatar
mb1
i already have redline from my 60k tuneup, i was just wondering whether you aare supposed to replace it at 120k mile also.
Old Jan 2, 2005 | 06:11 PM
bill927's Avatar
Good question, how often is sythetic trans oil supposed to be replaced? Anyone?
Old Jan 2, 2005 | 06:17 PM
MDeezy's Avatar
stock fluids last for about 60K right? I'd assume it can go atleast 60.
ih regular engine oil last 3K and syth can go atleast 6K then I Know tranny fluid isnt the same as engine oil but It should be able to do atleast 100K ?
Old Jan 2, 2005 | 07:09 PM
vortechpower's Avatar
I would change gear oil between 40-60k miles. I use redline and it comes in qts. or gallons.
rbuswell
Nov 17, 2016 04:54 AM
Mrbizness1
Aug 18, 2015 08:43 PM
scarletsosa
Aug 17, 2015 09:09 PM
egali045
Aug 16, 2015 01:19 PM
