O2 Sensor Reading
Old Jan 2, 2005 | 04:42 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
O2 Sensor Reading
Can anyone tell me if the bank One oxygen sensor is bad?
Monitored Test Results (Mode $06)
Test ID ($01) Catalyst Monitoring Value 2.000 Min 0.000 Max 95.000 Units Unitless
Test Description ($01) Three-Way Catalyst Function - Bank 1
<P>
Test ID ($03) Catalyst Monitoring Value 6.000 Min 0.000 Max 95.000 Units Unitless
Test Description ($02) Three-Way Catalyst Function - Bank 2
Test ID ($05) Oxygen Sensor Heater Monitoring Value 1.000 Min 0.000 Max 63.000 Units Unitless
Test Description ($03) Undocumented CID
Test ID ($06) Oxygen Sensor Heater Monitoring Value 15.000 Min 2.000 Max 0.000 Units Unitless
Test ID ($09) Oxygen Sensor Heater Monitoring Value 46.000 Min 0.000 Max 99.000 Units ms
Test Description ($04) Heated Oxygen Sensor - Bank 1 Sensor 1
Test ID ($0A) Oxygen Sensor Heater Monitoring Value 60.000 Min 60.000 Max 0.000 Units Unitless
Test Description ($04) Undocumented CID
Test ID ($0B) Oxygen Sensor Heater Monitoring Value 33.000 Min 0.000 Max 34.000 Units mV
Test ID ($0C) Oxygen Sensor Heater Monitoring Value 60.000 Min 0.000 Max 199.000 Units mV
Test ID ($0D) Oxygen Sensor Heater Monitoring Value 0.000 Min 0.000 Max 44.000 Units sec
Test ID ($11) Oxygen Sensor Heater Monitoring Value 42.000 Min 0.000 Max 99.000 Units ms
Test Description ($05) Heated Oxygen Sensor - Bank 2 Sensor 1
Test ID ($12) Oxygen Sensor Heater Monitoring Value 82.000 Min 60.000 Max 0.000 Units Unitless
Test Description ($05) Undocumented CID
Test ID ($13) Oxygen Sensor Heater Monitoring Value 34.000 Min 0.000 Max 34.000 Units mV
Test ID ($14) Oxygen Sensor Heater Monitoring Value 34.000 Min 0.000 Max 199.000 Units mV
Test ID ($15) Oxygen Sensor Heater Monitoring Value 0.000 Min 0.000 Max 44.000 Units sec
Test ID ($19) Oxygen Sensor Heater Monitoring Value 3.000 Min 3.000 Max 0.000 Units Unitless
Test Description ($06) Undocumented CID
Test ID ($1A) Oxygen Sensor Heater Monitoring Value 48.000 Min 48.000 Max 0.000 Units Unitless
Test ID ($1B) Oxygen Sensor Heater Monitoring Value 31.000 Min 0.000 Max 42.000 Units mV
Test Description ($06) Heated Oxygen Sensor - Bank 1 Sensor 2
Test ID ($1C) Oxygen Sensor Heater Monitoring Value 48.000 Min 0.000 Max 199.000 Units mV
Test Description ($06) Heated Oxygen Sensor - Bank 1 Sensor 1
Old Jan 2, 2005 | 05:06 PM
CystumMax's Avatar
Anyone?
Bump
Old Jan 2, 2005 | 05:15 PM
nick's Avatar
what did you use to get those readings ?
Nick.
Old Jan 2, 2005 | 06:36 PM
CystumMax's Avatar
Nick.
Its a ODBII reader, Bought it on ebay, its called "AutoEnginuity".
Old Jan 2, 2005 | 09:31 PM
nick's Avatar
I concur, G14 clearance is required to decipher this load of traffic.
I really don't know what to tell you, but healthy O2 sensor should flactuate between .450 Volt
Nick.
Old Jan 3, 2005 | 05:38 AM
CystumMax's Avatar
Nick.
Thank you. I'll see if i can get better result with the diffrent option in the ODBII reader.
bbsitum
Sep 6, 2019 07:31 PM
conansriver
Sep 11, 2015 10:26 AM
sdotcarter
Sep 2, 2015 09:53 PM
