Knockings in front end.
Old Jan 3, 2005 | 07:49 AM
Old96MaxMan's Avatar
I am beginning to hear muffled knockings in the front end of my 96 Maxima when I turn and/or hit a big bump. Any idea of what could be wrong? I think it has something to do with my steering because at times it feels as though it is grinding. What should I do? Anyone else have this problem?
Thanks in advance for any feedback!
Old Jan 3, 2005 | 07:52 AM
mzmtg's Avatar
Minister of Silly Walks
Do you get the knocking sound when not moving, but just turning the steering back and forth?
Old Jan 3, 2005 | 08:07 AM
Yes, but it is a much worse knocking if I'm going over a bump while turning.
Old Jan 3, 2005 | 08:12 AM
mzmtg's Avatar
Sounds like you need new upper strut mounts (part 2 in the pic, ~$35 each from Nissan). It would probably be a good idea to replace the strut bearings as well (part 4 in the pic, ~$18 each from Nissan).
Old Jan 3, 2005 | 08:16 AM
Well that might explain it since I just installed new springs. I'll look into that, thanks for the info!
Old Jan 3, 2005 | 08:19 AM
mzmtg's Avatar
Ohhhh, since you just did new springs...
Go back and double check that your top nut on the strut and the 3 strut mounting bolts are all torqued to spec. They may have come loose, causing the knocking.
Old Jan 3, 2005 | 01:09 PM
Oh alright. I'm pretty sure that they're all tight though.
Old Jan 3, 2005 | 04:26 PM
michaelnyden's Avatar
how much would it be to replace a set of parts 1-7 in the diagram?
do you also have a pic of the rear suspension....not much to replace there I assume compared to the front...
wyobbagy
Jan 3, 2023 12:03 PM
Hdnseek
Sep 9, 2015 05:55 AM
jfl330
Sep 4, 2015 01:44 PM
