Bad Oxygen Sensor
Bad Oxygen Sensor
Can a bad Oxygen sensor cause the car smell bad? My car smells bad when it's idle. Did anyone remember their car smell bad before the Oxygen sensor went bad and they got CEL? thanks.
Originally Posted by 2 Da Max
is it the rotten egg smell? if so its the cat.
No it does not smell like rotten egg. More like fuel ratio is off, smell like the car is not burning fuel right.
Originally Posted by Ant96GLE
My car smelled bad... but I knew mine were dead. I'm still having the same problems. I think you should do what you recommended me to do... which I'm doing this weekend.. wow that was a confusing post.
Inspection/Maintenance Monitors Status
Name Status
Misfire Monitoring Complete
Fuel System Monitoring Complete
Comprehensive Component Monitoring Complete
Catalyst Monitoring Complete
Heated Catalyst Monitoring Not Supported
Evaporative System Monitoring Complete
Secondary Air System Monitoring Not Supported
A/C System Refrigerant Monitoring Not Supported
Oxygen Sensor Monitoring Complete
Oxygen Sensor Heater Monitoring Complete
EGR System Monitoring Complete
Monitored Test Results (Mode $06)
Test ID ($01) Catalyst Monitoring Value 2.000 Min 0.000 Max 95.000 Units Unitless
Test Description ($01) Three-Way Catalyst Function - Bank 1
Test ID ($03) Catalyst Monitoring Value 6.000 Min 0.000 Max 95.000 Units Unitless
Test Description ($02) Three-Way Catalyst Function - Bank 2
Test ID ($05) Oxygen Sensor Heater Monitoring Value 1.000 Min 0.000 Max 63.000 Units Unitless
Test Description ($03) Undocumented CID
Test ID ($06) Oxygen Sensor Heater Monitoring Value 15.000 Min 2.000 Max 0.000 Units Unitless
Test ID ($09) Oxygen Sensor Heater Monitoring Value 46.000 Min 0.000 Max 99.000 Units ms
Test Description ($04) Heated Oxygen Sensor - Bank 1 Sensor 1
Test ID ($0A) Oxygen Sensor Heater Monitoring Value 60.000 Min 60.000 Max 0.000 Units Unitless
Test Description ($04) Undocumented CID
Test ID ($0B) Oxygen Sensor Heater Monitoring Value 33.000 Min 0.000 Max 34.000 Units mV
Test ID ($0C) Oxygen Sensor Heater Monitoring Value 60.000 Min 0.000 Max 199.000 Units mV
Test ID ($0D) Oxygen Sensor Heater Monitoring Value 0.000 Min 0.000 Max 44.000 Units sec
Test ID ($11) Oxygen Sensor Heater Monitoring Value 42.000 Min 0.000 Max 99.000 Units ms
Test Description ($05) Heated Oxygen Sensor - Bank 2 Sensor 1
Test ID ($12) Oxygen Sensor Heater Monitoring Value 82.000 Min 60.000 Max 0.000 Units Unitless
Test Description ($05) Undocumented CID
Test ID ($13) Oxygen Sensor Heater Monitoring Value 34.000 Min 0.000 Max 34.000 Units mV
Test ID ($14) Oxygen Sensor Heater Monitoring Value 34.000 Min 0.000 Max 199.000 Units mV
Test ID ($15) Oxygen Sensor Heater Monitoring Value 0.000 Min 0.000 Max 44.000 Units sec
Test ID ($19) Oxygen Sensor Heater Monitoring Value 3.000 Min 3.000 Max 0.000 Units Unitless
Test Description ($06) Undocumented CID
Test ID ($1A) Oxygen Sensor Heater Monitoring Value 48.000 Min 48.000 Max 0.000 Units Unitless
Test ID ($1B) Oxygen Sensor Heater Monitoring Value 31.000 Min 0.000 Max 42.000 Units mV
Test Description ($06) Heated Oxygen Sensor - Bank 1 Sensor 2
Test ID ($1C) Oxygen Sensor Heater Monitoring Value 48.000 Min 0.000 Max 199.000 Units mV
Test Description ($06) Heated Oxygen Sensor - Bank 1 Sensor 1
thats what happens when you have so many gurls in your car, the perfume justs builds up and cause the car to smell like crap, lol
lol
that's funny
lol
1 for every day of the weekend isnt bad...
lol i hope your not the type of person that forgets names!! lol or youll have none for next week!
btw cystum max what are you going to do now? change o2 sensors or new cat?
