Taking timing chain cover off...questions
Old Jan 4, 2005 | 02:52 PM
|Bijan|'s Avatar
UCF Lexus
Does the oil pan HAVE to come off in order to get the timing chain cover entirely off? I've got EVERY bolt off...I've checked 3x. All bolts to the LEFT of the front valve cover are off.....
Is the gasket connecting the oil pan to the block kicking my as.s or did I miss something?
Old Jan 4, 2005 | 05:15 PM
delacruz_17's Avatar
YES!!!!!! you MUST take off the oil pan, there are two pretty big bolts under there to remove the timing chain cover. Trust me i broke the time chain cover trying to take it off, it is not a cheap part either
Old Jan 4, 2005 | 05:50 PM
JoeB
You only have to take off the lower oil pan to get those bolts. Piece of cake after what you went through to get all the screws out of the cover.
Old Jan 5, 2005 | 08:36 AM
|Bijan|'s Avatar
UCF Lexus
hmm, i guess japs really know how to seal an oil pan...I've tried everything
Old Jan 5, 2005 | 08:43 AM
mzmtg's Avatar
Minister of Silly Walks
Once you get all the oil pan bolts off, you may have to whack it with a mallet to break the seal.
Old Jan 5, 2005 | 09:12 AM
|Bijan|'s Avatar
UCF Lexus
Been there done that got the t-shirt. I'll see what else I can pry in btwn the gap...
Old Jan 5, 2005 | 09:23 AM
MDeezy's Avatar
damn, didnt know you had to remove the oil pan as well, I guess this is a job best to do when an oil change is comming around.
regular oil pan sealant from an auto store will work when putting back together?
Old Jan 5, 2005 | 01:58 PM
JoeB
It's sealed on from the factory with RTV sealant. Takes a little persasion to get off but once you break the seal it should come right off. Make sure all surfaces are oil free when you put it back together. Yes any auto parts store will carry RTV(silicone) sealer.
Old Jan 5, 2005 | 02:02 PM
Jeff92se's Avatar
I'm needing a caw
http://www1.autozone.com/servlet/UiB...3d801f49a8.jsp
Old Jan 5, 2005 | 02:48 PM
MDeezy's Avatar
sweet, so the whole piece that comes off look like
I know thats the mounting bracket for a sueper charger for the max but thats what the side cover looks like when it comes off? or it a smaller piece?
just getting clarification for when I do mine as well.
Old Jan 5, 2005 | 02:59 PM
SE-Rfornow's Avatar
Wow... awesome timing with your post. I am at the same place as you right now and while the top part of the cover was opening... the bottom wouldn't budge. After dinner I'm going to try this and hopefully it will be what I need.
Why are you taking your timing chain cover off? Also how easy was getting the crankshaft pulley bolt off?
Good luck... I'd say use a razor to puncture all around the rtv to at least reduce some of the suction and double check to see if each screw is out.
Old Jan 5, 2005 | 03:37 PM
SE-Rfornow's Avatar
If you follow the autozone link posted a coupe posts up... scroll down a little and you will see a drawing of what the timing chain cover looks like removed.
Paul
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
maxinout93
Oct 27, 2015 01:29 PM
Finkle
Sep 27, 2015 09:53 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Team STILLEN
Aug 10, 2015 04:29 PM
