98 max, cold start problem....
Old Dec 24, 2004 | 06:13 AM
robnrob10's Avatar
been going on for at least 2 years. when cold if will start right up then instantly die. after 2-3 tries it will start. or you can give it a little gas to keep rpms up and it will start fill like it wants to die then be ok.
once it's been run a few minutes it will be fine unless it sits for a couple hours. other than this the car runs perfect. plugs are new.
tks
Old Jan 5, 2005 | 03:48 PM
Doon Sysongdeth's Avatar
have the same problem on my 98 max. no one could figure it out. if you found the solution to it let me know. thanks
Old Jan 5, 2005 | 03:52 PM
2 Da Max's Avatar
ok guys.... get 2 dollars and go buy throttlebody cleaner. clean around the throttlebody, the butterfly and behind the butterfly. you will also notice better idle and quicker throttle response. same thing happened to me, didnt believe that a dirty tb was a problem
02PearlSE
Oct 7, 2015 02:12 AM
FlaMark
Aug 21, 2015 11:06 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
kirkhilles
Aug 8, 2015 10:53 AM
