Misfire, Misfire, Misfire HELP
I've been misfiring and I cant pinpoint what part to change.
The car misfires when I floor it and the revs go above 4000 RPM. Also I've been hearing some misfires when the car is idle (these are very suddle). The car also feels like it is jerking at times (comming from the front of the car).
I checked the ECU. It read 0505. Meaning no problems.
I can say that it is either the spark plugs, fuel injectors, or the ignition coils. I dont know which of them. Maybe even a sensor?
I tested the ignitions coils like this:
While the car was one, I disconected the plugs to each ignition coil one by one, and I can hear that engine loses power when I do this. So I think it may not be the coils, but I could be wrong.
How do you test the coils for sure? Same goes for the spark plugs and fuel injector. How do you check them?
What do you think might be the problem?
Thanks for the help in advance. It sucks when a Saturn is competativly racing with me on the street because my engine misfires.
Try resetting the ECU before you do anything first? I know it sounds retarted but my car had a misfire problem about 5 months ago. After going through the car's wiring, checking coils and plugs, etc; I found that cylinder 1 was the culprit. To my surprise, after replacing the coil it would still misfire. In a final act of desperation I ended up unplugging the battery for a day and its been running fine ever since. Hope this will help ya.
One more thing, on my 95 it wasn't the coil pack it was the injector that was bad. To test those, get a ohm meter and they should ohm out around 12 ohms average +/- a few ohms. If one of them seems extremely high compared to the others, thats the bad one
Originally Posted by Adrian112597
First unscrew all of the screws on the coils, then with the car running pull off one coil pack at a time until the misfire stops.
Originally Posted by adithius
The misfires dont happen all the time.
it is very possible to get a bad misfire and not get a CEL, happend to me a few times. One would think the ECU would throw a code right away but things don't always work out so perfectly. Pulling each coil while the car is running is a good way to check, and if no change occured when the coils were disconnected then I would move on to the injectors. You can either check the ohm resistance on each one, or use a screw driver or a mechanics stethescope (sp?) to listen to each one. They should tick really fast. If one sounds different than the others than it could be your culprit. The middle one on the rear bank is hard to get to without removing the manifold though. Also pull the plugs and see how the look
If you have no luck with the coils, then I would say to double check each injector to make sure that they are fully pressed down and "clicked" into place. I had a similar problem and could not figure it out for the life of me so one day I randomly checked to make sure the injectors were properly seated and my cylinder one injector hada lil play in it so i pushed it down and it clicked into place. The difference was like night and day. By the way, do you have a put put sound from the exhaust while idling?
Sounds like bad coils to me. Just because a coil works fine at idle doesn't mean it works fine at WOT above 4000rpm. I'm willing to bet money it's your coils. Your problem is identical to the problem I had. No misfire code, but horrible misfiring, couldnt go above 3500rpm at WOT. Car idled absolutely perfectly. I replaced all my coils and the problem is totally cured. It's your coils.
jmlee44
Oct 2, 2022 02:13 PM
ballerchris510
Sep 11, 2015 05:29 PM
