Please help.....I accidently put some window washer
Old Jan 5, 2005 | 08:57 AM
mslovergirl's Avatar
Hey guys, I accidently put some window washer fluid in the anti-freeze container with the yellow cap. I know this is very stupid of me but i wasn't thinking. I didn't put much in there (about 1/2 cup) but i'm still concerned that i may do some damage. Is there any advice you can give me to resolve this problem or should i relax and not worry about it. Please, any help would be greatly appreciated.
btw, my car is a 95 max with 117,000 miles.
Old Jan 5, 2005 | 09:02 AM
MrEous's Avatar
^ Jeff™
IMO a 1/2 cup would be diluted enough to not cause a single problem.
Old Jan 5, 2005 | 09:03 AM
MDeezy's Avatar
half a cut should do any damage at all, it might still be in the container, that container is a resevoir and is only used when the car is getting low in coolant so it takes from there.
you could:
take out that container (pops out easily) empty and refill with coolant to appropriate Max line.
not worry about it
or flush the all the coolant out.
I think you would be fine and at most I would empty the resevoir container.
Old Jan 5, 2005 | 10:44 AM
1MAX2NV's Avatar
You can take out the container and dump it out. If not, just go get a cooling system flush for ~$80. You probably need that done anyway. It's recommended to flush your cooling system every 2 years. Your water pump, radiator and water passage in your engine will thank you.
Old Jan 7, 2005 | 09:10 PM
Thank you guys for the info. It's greatly appreciated.
smiles...
markevans999
Sep 10, 2015 04:29 PM
videomano
Sep 8, 2015 03:28 PM
ef9
Sep 5, 2015 11:18 PM
maximusrising
Sep 4, 2015 06:31 PM
