Urgent:: Problems with 96 Maxima A/T
Old Jan 5, 2005 | 03:49 PM
beatstriken's Avatar
My girlfriend drives an automatic 96 Maxima......
I'm getting code 0304 - Knock sensor or circuit fault
and 1105 - A/T third gear signal fault
the knock sensor on this thing is a biznitch to get to, and look slike you have ot remove the intake manifold to get to it... and i have no idea what to do with the A/T third gear signal fault????
any ideas how much this work could cost?
Even though its still a VG engine, its definetly different than my Z
please email me.
Thanks in advance
Old Jan 5, 2005 | 04:14 PM
Ant96GLE's Avatar
Maybe because its not a VG
Its called a VQ... its wayy different than your VG... anyways, the knock sensor is no big deal, you dont have the remove the intake manifold, read the stickies and you'll see. All you need is a swivel 12mm socket and looooong extension
Old Jan 5, 2005 | 04:16 PM
thanks...
what about that code 1105 ? the A/T third geear signal fault.
Old Jan 5, 2005 | 04:28 PM
Ant96GLE's Avatar
I dunno... not familiar with it.. check the stickie on ECU codes
Old Jan 5, 2005 | 04:29 PM
Ant96GLE's Avatar
1103 1104 1105 1106
Since DTCs 1103 to 1106 deal with the transmission, there is info on the 1106 DTC. Everywhere you see "4th gear", simply substitute "1st gear".
Diagnostic Trouble Code 1106 means "Automatic Transmission 4th gear malfunction."
This malfunction is detected when the automatic transmission does not shift into fourth gear or the torque converter clutch does not lock up as instructed by the Transmission Control Unit. The factory service manual lists these possible
causes...
- Shift solenoid A
- Shift solenoid B
- Overrun clutch solenoid valve
- Line pressure solenoid valve
- Each clutch
- Hydraulic control circuit
- Torque converter clutch solenoid valve
You can do some troubleshooting without opening the automatic transmission. Find the harnesses which emanate from the transaxle. One of them terminates in a brown plastic connector with eight pins. This is connector F42, located (approximately) above the transaxle case and below the black plastic engine air intake ductwork. With the engine off, disconnect F42. You want to measure the transmission side of F42. Hold the connector such that the plastic latch is at the top. You should now see two rows of four terminals. These are numbered (top row, left to right) 1 - 4, and (bottom row, left to right) 5 - 8. Make resistance measurements between a clean ground and the following terminals:
#1, Shift solenoid B, 20 - 40 ohms.
#2, Shift solenoid A, 20 - 40 ohms.
#3, Overrun clutch solenoid valve, 20 - 40 ohms.
#4, Line pressure solenoid valve, 2.5 - 5 ohms.
#5, Torque converter clutch solenoid valve, 10 - 20 ohms.
There is also a "bench test" procedure for testing these solenoids with a 12 volt supply such as a car battery. However, this requires removal of the shift solenoid valve assembly. I don't know if you want to get involved with that.
Lakersallday24
Nov 7, 2024 07:31 PM
Samedi
Aug 13, 2015 04:05 PM
Hawkeye61
Aug 12, 2015 06:45 PM
09maxshawn11
Aug 9, 2015 01:13 PM
yat70458
Aug 3, 2015 01:16 PM
