Prewired for foglights?
Old Jan 5, 2005 | 04:38 PM
guyfromkop's Avatar
how would i know if my 96 gle is prewired for foglights?
Old Jan 5, 2005 | 04:44 PM
sunten1
look where you turn your head lights on and off, there should be one for fogs there, if there isn't well then you most likley don't have it
Old Jan 5, 2005 | 05:27 PM
azmaxipad's Avatar
not correct it should be pre wired you need to look at where the fog lights would be mounted and a wire should be up there on both left and right sides. i have a turn signal stalk w/ fog light switch (not standard equip.) if you plan on adding fog lights
Old Jan 5, 2005 | 07:39 PM
Dagger969's Avatar
So wait, to be prewired it should have the stalk or the wires or both?
Old Jan 5, 2005 | 07:42 PM
ymNA's Avatar
just wire no stalk
Old Jan 5, 2005 | 08:53 PM
HomerMAC's Avatar
Donating i30 Owner
i think the wiring is there.. but the switch with the headlight and turnsig on it i think u have to get new .. but the basic wiring is there.. (im 99% shure)
Old Jan 5, 2005 | 09:03 PM
OneToughMax's Avatar
the wiring is there. you just need to add a relay, and swap the non-fog turn signal stalk to fog turn signal stalk. all the wiring is there. the harnesses for the lights are taped up under the bumper, and the harness that plugs into the stalk is taped up under the steering shroud
Old Jan 6, 2005 | 05:54 AM
VOX98's Avatar
OneToughMax is correct. My '98 GXE is wired the exact same way. Fogs are going in once spring roles around.
Old Jan 6, 2005 | 06:44 AM
guyfromkop's Avatar
will these wires work for aftermarket foglights?
Old Jan 6, 2005 | 06:45 AM
SDB318's Avatar
i want to know too
Old Jan 6, 2005 | 11:12 AM
SDB318's Avatar
so can we use aftermarket fogs for these
Old Jan 6, 2005 | 11:24 AM
VOX98's Avatar
You should be able to...you would just need to clip off the factory wiring harness and splice in the wires to the aftermarket fogs.
Old Jan 6, 2005 | 12:17 PM
SDB318's Avatar
alright sweet thanks
Heat0212
Oct 24, 2020 12:36 AM
ricky7780
Nov 3, 2015 03:22 PM
Excalibur23
Oct 13, 2015 04:33 PM
Hdnseek
Sep 9, 2015 05:55 AM
