Crank Case Air filter...
Old Apr 24, 2001 | 08:41 AM
Stillnmax's Avatar
does this really do anything besides lower the temp... and will you notice any diff after doing this .... anyone with experiance in this area
Old Apr 24, 2001 | 10:14 AM
I30CeFiRo's Avatar
Nope, no big difference in any way. I'd say it's just for looks
Old Apr 24, 2001 | 10:20 AM
dmbrazilian's Avatar
Where can you get one? and about how much is it?
thanx
Old Apr 24, 2001 | 07:28 PM
got rice?'s Avatar
there isn't much reason to change out the stock system. just as long as the PCV valve is replaced before it becomes clogged, you'll be fine. to test the valve, just shake it. if it rattles, it's fine. you can clean it out with throttle body cleaner to remove any carbon deposits.
Old Apr 24, 2001 | 10:50 PM
BippuBenji's Avatar
Ok....
So after you put on the breather, what do you do with the end of the hose that was connected to the crank case? And, will oil leak into the breather?
tarun900
19
Dec 20, 2021 06:57 PM
TKHanson
Nov 24, 2018 01:39 AM
Justin Kroll
Oct 1, 2015 07:03 PM
zmcneely13
Sep 26, 2015 02:26 PM
rbaker100
Sep 25, 2015 07:52 PM
