Fuel Filter is going to be the death of me...
Old 01-08-2005, 11:17 AM
BigLou93SE's Avatar
Ok, I started at about 12:30 today, and it's now about 2:30. I"M NOT EVEN HALF WAY THERE. I have the top fuel line off, and have the clamp for the bottom fuel line loosened and hanging on to the fuel line. I cannot get the bottome fuel line off. In about an hour's worth of cranking the engine/pulling on the line, I've gotten about an eigth inch of movement. PLEASE give me suggestions on what to do. I have the intake completely off, I have an abs system, and have cranked my poor engine at least 50 times so far. I don't know if this is the original filter (I now have 135k mi) which might explain why this is so damn difficult. I don't know. Please shed some light on this.
Lou
BigLou93SE is offline
Old 01-08-2005, 11:23 AM
wat
BlueC's Avatar
Lou
Its not easy, took me probably an hour to do the entire thing. Keep working at it, you will eventually get it. Theres really nothing that can help, so just keep working at it.
BlueC is offline
Old 01-08-2005, 11:25 AM
Tyrexx's Avatar
Use pliars, but wrap them in tape so you dont rip the hose. Keep twisting back and forth.
Tyrexx is offline
Old 01-08-2005, 11:32 AM
ronin22357's Avatar
i had the same problem , all you need to do is keep twisting it back and forth. they dont pull straight off , they are twist offs
ronin22357 is offline
Old 01-08-2005, 11:37 AM
BigLou93SE's Avatar
That's what I've been trying to do, but since I have ABS there's not a lot of play room to do that. Thanks for the replies, I have to go to work, so tomorrow afternoon I will get back after it.
Old 01-08-2005, 11:38 AM
mansurxk's Avatar
twist it off, you defainetly wont pull that badboy off.
mansurxk is offline
Old 01-08-2005, 11:40 AM
no more maxima...
kingrukus's Avatar
I had a hard time removing my hoses. I sprayed wd40 around the top of the hose, and allowed it to seep in a bit. Then I used a flat head screw driver and gentally pried between the top of the hose and the filter until I was able to start twisting the hose with my hand off.
kingrukus is offline
Old 01-08-2005, 11:43 AM
BigLou93SE's Avatar
Again, thanks for the information.
Old 01-08-2005, 12:04 PM
deezo's Avatar
I was going to ask if you had ABS because it makes things worse.Try removing your intake assembly to make more room for yourself. That's what I do now because my arms are too big to fit in that area and I don't have ABS.
deezo is offline
Old 01-08-2005, 12:16 PM
caudio51's Avatar
oh boy, this is my next project.....and I just looked with ABS it is a tight fit
caudio51 is offline
Old 01-08-2005, 12:36 PM
l3ftonm3's Avatar
yah I did mine yesterday along wth the knock sensor, what a pita. But twisting definitely was the key for the fuel filter.
l3ftonm3 is offline
Old 01-08-2005, 12:41 PM
caudio51's Avatar
yea knock sensor is on the list too
caudio51 is offline
Old 01-08-2005, 12:46 PM
BigLou93SE's Avatar
yup -- knock sensor is on my to do list also...
Old 01-08-2005, 12:51 PM
caudio51's Avatar
ive read the haynes manual on both, they dont seem hard just a pita fromw what I have read/heard
caudio51 is offline
Old 01-08-2005, 01:02 PM
ChristheNite
Everytime I am working on my car and I'm at the point when I'm like AHH I CANT DO THIS - my dad says "If I told you I would give you a million dollars to get this done - you'd find a way to get it done". 9 times outta 10 thinking about that annoys me to the point I get it done. So just keep that in mind, and you'll get that hose taken off.
Old 01-08-2005, 01:06 PM
caudio51's Avatar
haha thats good
caudio51 is offline
Old 01-08-2005, 02:05 PM
RaWr!!! ('''_(o_O)_''')
Vlasic's Avatar
i was never able to get them off by twisting so i just cut them. the line is long enough to let you cut about half an inch off right at the fuel filter.
Vlasic is offline
Old 01-08-2005, 02:42 PM
Ant96GLE's Avatar
So I guess your going to cut half an inch every time you change your fuel filter?
Ant96GLE is offline
Old 01-08-2005, 02:48 PM
MaximA StyLeZ's Avatar
yea.... the filter was a real pita. had to cut both bottom hose and top hose to take off. that was easy. tha hardest part was putting it back on.. we were forced to lube up the hoses and try to slip it in. finally after numerous attempts it was finally achieved.
whata f*ckin PITA. good luck
MaximA StyLeZ is offline
Old 01-08-2005, 03:05 PM
mansurxk's Avatar
yeah i dont think cutting it off is a real solution to this. use some needle nose pliers or twist from side to side and pull it off then.
mansurxk is offline
Old 01-08-2005, 03:25 PM
PLkiller's Avatar
I just changed my filter last night..I ended up cutting the fuel lines. I would recommend it to you to...just make sure u don't cut too far..
ohh yea, and it was a ***** to take out...
PLkiller is offline
Old 01-08-2005, 03:28 PM
lefty
I have no real mechanical experience but was able to take the filter off by using a small flat head screwdriver and allowed some air to get in between the hose and the filter and just pryed it off in like 3 min. Just don't pull it off as everyone said. Take your time and get something in there and pry it off.
Old 01-08-2005, 03:43 PM
Ant96GLE's Avatar
Damn you guys give up easily... twist with a set of needle nose pliers or use a flat head screwdriver to pry it down, I have ABS as well but damn its not that serious
Ant96GLE is offline
Old 01-08-2005, 04:17 PM
Vlasic's Avatar
i just have absolutely no patience for that ****. id rather spend 5 bucks to replace the 2 foot hose then spend half an hour twisting that **** off
Vlasic is offline
Old 01-08-2005, 04:27 PM
Well I should wrap this up before I start to ramble.
CystumMax's Avatar
If you want to get it replaced, go to Nissan dealer shop, and buy a Filter for a 96 300 ZX, it would fit fine. Good luck.
CystumMax is offline
Old 01-08-2005, 04:37 PM
BluFlame's Avatar
+1
take off intake hoses + MAF assembly before doing this,
1) take off top hose,
2) pull filter out of the clip
3) bend the filter 90 deg towards the front of the car, exposing bottom clamp
4) loosen the bottom clamp, using a flat screw driver pry the hose off.
15mins tops,for the whole thing.
BluFlame is offline
Old 01-08-2005, 04:43 PM
CystumMax's Avatar
Originally Posted by BluFlame
+1
Pull the Fues for the Fuel pump and give the car a start, My 99 Was a bI)ch to take off. It would not come out.
Old 01-08-2005, 04:48 PM
bigx323's Avatar
i jst grabed the hose with one hand and the filter with the other one and pulled as hard as i can, and it came off
bigx323 is offline
Old 01-08-2005, 04:51 PM
CystumMax's Avatar
you are lucky i had no luck.
Old 01-08-2005, 05:05 PM
Ant96GLE's Avatar
Yes you did... it just wasnt good luck
Ant96GLE is offline
Old 01-08-2005, 06:08 PM
enjetek's Avatar
dude it is so easy. i did mine in 5 minutes and 10 mins for my friends altima. it was harder because i had only one damn tool which was a screwdriver...just twist and twist...
enjetek is offline
Old 01-08-2005, 07:54 PM
{-_-}'s Avatar
if you have small hands you can do this pretty quickly... get your girlfriend or sister to do this...
as everyone in the thread have said... twist and pull... that's the only way.
and patience... it took me about an hour or so for me to do the entire job.
{-_-} is offline
Old 01-08-2005, 08:03 PM
BigLou93SE's Avatar
Ok, well I had taken off the intake assembly to the throttle body, and I did take out the fuse to the fuel pump and cranked at least 50 times to try to relieve pressure build up. I'll definately try with the screwdriver/prying trick after I give the twisting with tape-wrapped pliers a go. Thanks for the help everyone. I hope my car feels better, I know it probably needs it.
Old 01-08-2005, 09:17 PM
Ant96GLE's Avatar
If its your girl, you can sit back and enjoy the view
Ant96GLE is offline
Old 01-08-2005, 10:17 PM
{-_-}'s Avatar
LOL... very true... very true...
{-_-} is offline
Old 01-08-2005, 10:22 PM
CystumMax's Avatar
LOL I agree.
Old 01-08-2005, 11:17 PM
lefty
Let us know how it goes. As mentioned, don't just yank on it. Get a scredriver between the rubber hose and the neck of the fuelfilter and pry it to get some Air inbeteween than work it. Common sense. i.e. Tough to get a condom off by pulling it off from the ends however, if you lift it off the bottom and get some air in between, you can break the seal.
Old 01-09-2005, 12:00 AM
MaxGordon7's Avatar
wow im lucky i did my filter today took no longer then 10 maybe 15 mins, i guess we got alot of weaklings! haha or maybe the 97 maxs are just easy on replacing it
MaxGordon7 is offline
Old 01-09-2005, 04:47 AM
BigLou93SE's Avatar
I was saving that one for the knock sensor . Yeah, I have enough room without the intake in, so I'll be back on later to update.
Old 01-09-2005, 11:44 AM
goodhead's Avatar
lmao
goodhead is offline
Quick Reply: Fuel Filter is going to be the death of me...
