4 struts or 2 ft struts and 2 shocks???
Old Jan 10, 2005 | 09:44 AM
sunnyb32's Avatar
I need new suspension on my max that has original 150k miles
now i dont know whether the maxima has 4 struts or 2 struts and 2 shocks
i called sears for an estimate they gave 585 for 4 struts and they arnt even sure until bring the max in but i dont wannta drive it around aimlessly since they are soo bad.
thanks
Old Jan 10, 2005 | 09:53 AM
Dagger969's Avatar
four struts
Old Jan 10, 2005 | 10:06 AM
Y2KSESteve's Avatar
2 struts up front and 2 shocks in the rear.
Old Jan 10, 2005 | 10:08 AM
adithius's Avatar
4 struts. So they are charging you $300 - $400 for labor. What a bend over charge. DIY man. Cheap Monroe struts too.
Dont forget you have to get an alignment after you change them.
Old Jan 10, 2005 | 10:13 AM
MDeezy's Avatar
Dont know if I'm the only one wondering but what is the difference between struts and shocks? I thought shock its just an older term for struts, and something technical also.
Old Jan 10, 2005 | 10:17 AM
Dagger969's Avatar
To my knowledge, and I could be very wrong on this, a strut is a shock with a platform on it for a coil spring whereas a shock is just a shock.
Old Jan 10, 2005 | 10:20 AM
mzmtg's Avatar
Minister of Silly Walks
We've been over this way too many times.
Technically, all 4 dampers are struts. BUT, the rears are not MacPherson struts. For this reason, most people just call the rears shocks, even though it's incorrect.
Old Jan 10, 2005 | 10:23 AM
Dagger969's Avatar
Most of us havent ben here for 5 years. But thankyou for explaining it again. Now I have to go find out what a MacPherson strut is, lol.
Old Jan 10, 2005 | 10:24 AM
sunnyb32's Avatar
OK so what should I get done for the BACK lol should i put in 4 struts or 2 struts and 2 shocks????
cuz dealer told me i have 2 strut and 2 shock all the local shops tell me i have 4 struts.....
Old Jan 10, 2005 | 10:25 AM
Dagger969's Avatar
he just said the difference.
Old Jan 10, 2005 | 10:26 AM
mzmtg's Avatar
It doesnt matter what they call them. You want 4 new dampers.
Any price over $250 for installation is a rip off. It's a 3 hour job, don't let them tell you any different.
Old Jan 10, 2005 | 11:12 AM
DAVE Sz's Avatar
Hooooooonda.....
If the FSM calls the fronts struts and the rears shocks, I'm gonna do the same.
Old Jan 10, 2005 | 11:15 AM
mzmtg's Avatar
Struts also perform a second job. Unlike shock absorbers, struts provide structural support for the vehicle suspension, support the spring, and hold the tire in an aligned position. Additionally, they bear much of the side load placed on the vehicle's suspension. As a result, struts affect riding comfort and handling as well as vehicle control, braking, steering, wheel alignment and wear on other suspension components, including tires.
http://www.monroe.com/tech_support/tec_struts.asp
Old Jan 10, 2005 | 11:50 AM
Terran's Avatar
...i called sears for an estimate they gave 585 for 4 struts...
OMG, they're really ripping you off. You could get a set of illumina's and have them installed for that much (probably a bit less). If you're sticking with stock springs just get some tokico blues or KYB GR2's and find some independent (non chain) to install them. probably cost $300-400 at the most.
Old Jan 10, 2005 | 02:04 PM
goodhead's Avatar
if you drive to ct ill do them for you for a big bottle of stoli rasp
i might steal your blower resistor while im at it LOL
Old Jan 10, 2005 | 02:10 PM
95nissanMax's Avatar
i just got my AFTERMARKET springs and struts for 350 shipped and 150 for install and 50 for allinement=$550=u getting ripped off unless you are getting upgraded springs struts.
Stagnet04
Oct 11, 2015 08:16 PM
maxima-junky
Oct 7, 2015 06:13 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
