0401 Intake Air Temp?
Old Jan 10, 2005 | 01:31 PM
Gramdacious's Avatar
Ok, so I need to do a smog check to get registered in Cali, the problem is my SES light is on and the code 0401, Intake Air Temperature Sensor. Is this a sensor located near the mass air flow sensor right behind the intake cone filter? Is it connected to the "ram-air" black plastic inlet that connects to the air box? If so, this is valuable info because I removed that piece and that might be the problem. Please help, I can't get a smog check until I can reset my check engine light.
Old Jan 10, 2005 | 01:35 PM
bklyncat718's Avatar
I have the same CEL code so if anyone has any info on it, it would help alot.
Old Jan 10, 2005 | 01:38 PM
l3ftonm3's Avatar
yes it is, if you have a cai, there should be a hole for it to plug into your cai, it should be after the maf going into your throttle body. Mine just had a plug over it, I took it out and put the sensor in. Rather than just having the sensor lay around.
Old Jan 10, 2005 | 01:51 PM
The "boost" sensor is the one that was connected to the ram air piece. I don't have a cold air intake, just a stillen pop charger. How do I "plug" it into the intake, it's just a wire harness plugged into a sensor that is connected to a metal bracket? Any info is much appreciated.
Old Jan 10, 2005 | 02:44 PM
felix's Avatar
Sittin' On Chrome
do these sensors go bad? I plugged mine in into the CAI pipe but the code came up a week later anyway. If so, where can you buy a new sensor?
Old Jan 10, 2005 | 02:50 PM
Where is the sensor? Is it the "boost" sensor connected to the ram air? Is it the sensor hanging down inside the mass air flow sensor? Is it behind the mass air flow sensor? I still am not sure where it is and how you fix it.
Old Jan 10, 2005 | 02:58 PM
l3ftonm3's Avatar
when I removed the ram air intake, the boost sensor would just be lying around. I just kept it connected and zip tied it to something up front. The other sensor I remember is in the ram air intake tubing, after it comes from the front it swoops down into the engine bay, there is a sensor there which I took and placed it into my intake.
Old Jan 10, 2005 | 07:21 PM
Mymax97's Avatar
Hi
I just took the acctual sensor out of the stock snorkle and attached it to the plug. No more CEL light for me!
Old Jan 10, 2005 | 08:04 PM
SXN's Avatar
SXN
yea, the stillen pop charger isnt CARB legal, so you wont pass california smog with that on your car. swap it out for the stock intake or, depending on the situation, prepare to 1. fail smog 2. have to pay a fix-it ticket 3. grease some wheels at the smog checking place
Old Jan 11, 2005 | 07:59 AM
SXN,
My car isn't a cali spec, it's out of state and emmission regulations are less strict, In fact I already passed in 2002 with flying colors. Sincen then I added a y-pipe, high-flow cat, and 2.5" b pipe with dynomax clone muffler. But I figured out what was wrong mith my intake air temp sensor.....I didn't have one. I accidently ripped it out with the ram air piece. So all I need is a new sensor to plug onto the wire harness and I'm sure I'll pass. Throw a little Lucas Oil injector cleaner, I'm sure I'm cool.
Old Jan 11, 2005 | 11:03 AM
felix's Avatar
Sittin' On Chrome
where can you buy a new one?
Old Jan 11, 2005 | 11:31 AM
Felix you can get them at a Nissan dealership. MSRP is about $64. Dealer price is about $51.
Old Jan 11, 2005 | 12:57 PM
SXN's Avatar
SXN
SXN,
just saying ive seen guys fail for a lot less. i wasnt referancing smog out put, but the visual inspection. cold airs, pop chargers, etc, dont usually pass that. just a heads up, you made it sound like a new part, that you were yet to smog here in california
Old Jan 11, 2005 | 01:47 PM
felix's Avatar
Sittin' On Chrome
Thanks.
Old Jan 11, 2005 | 02:32 PM
SXN,
thank goodness my girlfriend is a manager at a Mazda dealership, so she can get a service tech to smog it for only the cost of the certificate, like $8.75 or something rediculous like that. However their machine wont enable them to smog check if my check engine light is on, that's why I gotta get a new Intake Air Temp sensor. So I'm sure that they won't care whether I have an aftermarket intake or not. But thanks for the info. Cali smog is a bi*ch.
Old Jan 13, 2005 | 01:22 AM
SXN's Avatar
SXN
yea it definately is, thats why i was giving you a heads up
Old Jan 13, 2005 | 07:22 AM
thanks, I appreciate it. It's good to know people in high places.
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
hayne
Oct 5, 2015 11:53 AM
Sep 27, 2015 08:37 AM
