Broken Sunroof Help
Old Apr 24, 2001 | 05:31 PM
96 GREEN SE
My sunroof will not close unless I pull it shut and then the passanger side will not push up and go flush. I need help, does any one have ideas??
David
Old Apr 24, 2001 | 07:21 PM
Maxima1's Avatar
David
I have the exact same problem. You need to have a friend push the slide control switch to open the roof a couple of inches. Then have him close it while you pull the glass in and up with one hand on each side of the sunroof. The dealer told me my track is broken and I need a new one. It will cost about $1100.00 to fix, downer.
Old Apr 24, 2001 | 08:26 PM
DCmax's Avatar
Damn, thats a major bummer, seems like a common problem amongst Maxima owners. My mother had this same problem on her 90SE and the dealer quoted us a hefty sum to fix it.
Wish there was just some way to get it back on track.
Good Luck
Old Apr 24, 2001 | 08:47 PM
JoesMAX's Avatar
if you look in the owners manual theres a way you can shut your sunroof if it doesnt shut... you pop out the plastic piece around the switch and theres a little piece that you put the alan key into to manually crank it closed... the alan key is in the trunk with the lug nut wrench... never tried it but i read it in the manual once give it a shot
Old Apr 25, 2001 | 08:57 AM
96 GREEN SE
So Nissan makes ANOTHER ****TY PRODUCT, i wish they could do something right for once.
Old Apr 25, 2001 | 10:13 AM
B.C.
In the same boat
If it makes you feel any better, my sunroof broke about two weeks ago. Only one side seems to "pull" so I suspect one of the link wires is broken. I'm going to have Nissan fix it but you are right, it is very expensive. The whole headliner and steering wheel and/or seats have to be removed.
Let us know how it turns out.
Old Apr 25, 2001 | 10:49 AM
96 GREEN SE
I took out the headliner thats not bad, you will need to take out the pass seat to get it out. And as for a the sun roof it not bad just kinda heavy not i going to take it apart and see shat it looks like. I'll let you know.
Old Apr 25, 2001 | 09:23 PM
Roman-dude's Avatar
If anyone will end up with a tan sunshade in very good shape as a result of fixing the sunroof, please let me know- I need to replace mine
Roman
roman.vilner@att.net
Old Apr 25, 2001 | 09:30 PM
cooler2000's Avatar
Roman
roman, i saw those stuff on junk yards here in brooklyn or at junkyards in NJ (newark area) near Ikea store and they have a lot of wrecked maximas 95-99 years, so you can buy any part from them and its darn cheap since you go to car and remove a part by yourself, while you are there you can pick any other parts you will need.
Old Apr 25, 2001 | 09:48 PM
Roman-dude's Avatar
where in Bklyn?
cooler2000,
where in Brooklyn? I tried a couple but they did not have any? Also, where near IKEA? I went to IKEA but I have no idea where the junk yards are.
Thanks a lot
Roman
Old Apr 26, 2001 | 03:58 AM
party_boy's Avatar
at least the glass stays on the roof
those little metal? clips broke on mine and if i drive over 95 MPH the glass starts lifting and opens a couple of inches now. I have to get that fixed.
The sunroof is great when it works...and a b*tch to get it fixed.
Old Apr 26, 2001 | 07:10 AM
cooler2000's Avatar
Re: where in Bklyn?
cooler2000,
Thanks a lot
Roman
In Brooklyn go either on McDonald Ave and ave Y, there you will see small scale junk yard, or a several junk yards in sunset park area, its when you drive on 3th ave all way to Manhattan, you will see several junk yards on right side all of them operated by Spanish they could have import cars, but mostly its junk cars.
If i were you i would go to those huge junk yards near Ikea. How to find them?
When you drive to Ikea on NJ Turnpike, dont take Ikea exit, go to next exit, take it and drive around and you will find a huge street filled with so many junk yards thats where you can find virtually anything you want.
my email is cooler2000@zxmail.com if you have any qq.
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
bigdogsteve
Jan 31, 2018 04:18 PM
Forge277
Jun 13, 2016 09:26 PM
jonreidhead
Jan 6, 2016 09:38 AM
