DIY -Window Roll-Up Module Installed 4th Gen **Update**
Windows Roll-up module update, I finally finish it over the weekend. I used a keyless remote to activate the feature.
Here is the link of what i did:
http://www.cardomain.com/memberpage/691951/5
The last thread I open:
http://www.forum.maxima.org/showthre...=window+module
DIY- Windows Module Update
Using the lock feature on the oem remote as an activation will cause a bit of a problem. ex. when the windows are down, locking the door from the inside will activate the window roll-up.
The oem keyless remote don't have another channel for me to work with. I have decided to get a keyless remote unit. I went to ebay and got a keyless remote. Here's a link: $18 plus s/h
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
Here is the module link: $8 plus s/h
http://cgi.ebay.com/ws/eBayISAPI.dll...743600859&rd=1
I ran 3 wires to the driver and passenger door. The roll up wires from the switch will be need to be cut. One wire will go to the switch and one will go the motor. The 3rd wire will be use as the power source (red wire). I use the driver door as the power and the passenger as the ground wire(black wire). I don't want to open up the center console and look for the power source again.
Next, I connected the window module to the 3 wires. Tested it with tester. Now, I have the activation wire coming from the window module.
I need to figure out which button will activate the module. I picked the open button on the keyless remote. (Why not the lock button on the remote you ask? Button don't work. I got a crappy product) Hook up all the wires. Make sure all the wires are power and grounded. If one wires is not connected correctly, than it will not work.
Dress up the wires and you are good to go. Enjoy...
What do you guys think?
Originally Posted by craig10114
you can also go out and buy a halfway decent alarm and have it do the same thing.....all 4 of my windows go up and down *front and rear are independent of each other*
Yeah, I can do that. I could get a DEI alarm system and have it install. I have no plans on doing it on the max.
Originally Posted by minsbang
is this something that you would be able to do within 2 hours?
First time I did it, it took me long time. I spend most of my time researching the car, material and wires. If i would do it again, I think it would be a whole lot easier. Yes, I would say it will take me around 2 hours to have it install.
Finkle
09-27-2015 09:53 PM
