1996 GLE 90K Service
Old Jan 12, 2005 | 02:33 PM
fiat8's Avatar
Any input on what should be part of the 90k service for 96 Maxima GLE
Old Jan 12, 2005 | 02:44 PM
crouton's Avatar
I just had this done yesterday. At a dealership, which I'm already regretting.
Here's their breakdown of the 30k/60k/90k/etc servicelist:
  • Inspect and adjust belts.
  • Adjust clutch (manual).
  • Replace air filter.
  • Adjust valves.
  • Replace AIV filter.
  • Replace spark plugs.
  • 'Complete' steam clean of engine.
  • Inspect & top-off all fluid levels.
  • Inspect/verify lights, wipers, washers.
  • Replace charcoal canister filter.
  • Inspect PCV Valve & filter.
  • Drain, refill, and inspect cooling system.
  • Clean battery terminals and adjust water levels.
  • Inspect distributor cap, rotor, & plug wires.
  • 'Visually inspect' brake system lining and adjust rear (brakes?)
  • Replace fuel filter, inspect fuel system.
  • Inspect/adjust engine idle and timing.
  • Check/fix tire pressure.
  • Inspect steering & suspension.
  • Inspect wheel bearings.
  • Inspect exhaust system.
  • Replace Brake Fluid.
  • Inspect O2 sensor
  • Rotate tires.
Depending on what you've done since your last service it'll vary what you need, I imagine.
AaronL
Aug 8, 2020 10:31 AM
Unclejunebug
Apr 2, 2016 05:42 AM
RealityCheck
Oct 2, 2015 06:34 PM
Need help
23
Oct 2, 2015 08:56 AM
