Rear blinkers!!!
Old Apr 25, 2001 | 01:13 AM
ptrkng's Avatar
I have 95 maxima.
Anybody knows how to make your rear blinkers go rapidly??
Old Apr 25, 2001 | 04:49 AM
Daniel B. Martin's Avatar
Originally posted by ptrkng
I have 95 maxima.
Your post is ambiguous. Do your blinkers
1) now blink rapidly and you want to fix them, or
2) do they work normally but you wish they would blink rapidly?
1) Check the front blinkers. A burned out front blinker bulb will cause the front blinker to not work at all and the rear blinker to flash double speed, and vice versa.
2) There are accessory flasher units which speed up the rate of the blinking. These replace the stock flasher unit.
Old Apr 25, 2001 | 07:06 AM
JacksMax's Avatar
I have 95 maxima.
http://216.122.219.59/forums/showthr...threadid=23275
Old Apr 25, 2001 | 03:18 PM
clsund's Avatar
you can also go to www.hyperblinkers.com.
Old Apr 25, 2001 | 03:23 PM
Sonic's Avatar
The site has a coming soon sign.
Old Apr 25, 2001 | 04:54 PM
metallic97gxe's Avatar
Master Will
if you buy....
some...
-EUROLITE L.E.D. Bulbs #1156(Rear Turn Signals,Third Brake Light)=$7.50 each-AIE Online.
-EUROLITE L.E.D. Bulbs #1157(Park, Brake Lights,4)=$7.50 each-AIE Online.
l.e.d. bulbs use less power so by putting them in the rear only(to stay within the law,red or amber turn signals)they trigger the fast blink and it looks real cool....someone might say you ahve a blow front blinker but you know that it is not...I have these and they are fine and I have themn also in all 5 of my brake lights....also by these being white/clear when they are off if you have the red/clear mod you "see" no bulb....if you had an amber bulb in there then you see the hint of amber....try them...
see...no bulb in my turn signals....
matts95max
Apr 23, 2025 10:44 AM
GregL65
Jan 17, 2020 08:01 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
bbsitum
Sep 11, 2015 04:55 PM
