Front O2 sensor
Old Jan 13, 2005 | 03:23 PM
n2o_matt's Avatar
Front O2 sensor
i had a cel come on - took it to autozone to run the codes - front o2 sensor showed up - now i need to know how to remove the old one. I can't get a wrench at it Any suggestions? I don't have to drop the engine cradle do i?
Old Jan 13, 2005 | 03:38 PM
spddracer's Avatar
If you are changing it it is easier to cut the harness off the old one and use the boxed end of the wrench 22mm. since it is offset you can get on it that way. The new one you can get tight enough with the open end. Or you can buy the 02 sensor socket at sears or autozone ect.
rbuswell
Nov 12, 2016 04:11 PM
vingodine
45
May 21, 2016 12:46 PM
Slamrod
Sep 3, 2015 07:38 PM
homeyclaus
Sep 3, 2015 06:15 PM
