Please Helpp I Dunt Know What Happend Tryed To Find My Codessss
Jan 15, 2005 | 11:23 AM
Omg.... Im Really Stressing Out Right Now I Just When To Go Check My Codes Fro The First Time Everything Is Cool....it Looked Brand New Never Checked... NeWay It Felt Like The Screwdriver Wasnt In The Hole So I Started messin With It And I Guess I Turned It Or Somethin And The Car Is Fuked Up................. The Engine Light Went Off..... Then I Started It And Its Idelin At .2 Rpm And It Is Ruff As Hell And Wants To Stall What The Hell Did I Do And How Do I Fixxxxxx Itttttttttttt I Hope I Didnt Do Severe Damage...by The Way Like 45 Seconds Later The Check Engine Light Came On And I Left It
Helppp Meeeeeeeeeeeeeeee
Jan 15, 2005 | 11:31 AM
You forgot to set the screw back at its original position. That screw depending on where its set at can adjust idle which is wh ur idle is whack.
aww damn, so your turned it too much and too hard? if thats the case you could try turning it back to where you think is the original place.
does it still idle @ 200rpm after starting with the cel light?
Even though I can barely read that, your problem is that the screw isn't turned properly. If it is turned the wrong direction and you try to start the car it will stall out.
Jan 15, 2005 | 11:33 AM
awww snaps.. you f'ed up your diagnostic screw... time to get a new ECU.
Jan 15, 2005 | 11:38 AM
NOOOOOOOOOOOOOOOOOOOOOOOOOOOO are u serious what eles is there i cant get an ecu now!!! omg im really pissed......... how do i get it back to teh normal position....which way do i turn it to get it to higher rpm..like i really fuked up i dunno which way i turned it i was tryin to get the screwdriver in....yea after the light came back on its at 200
Jan 15, 2005 | 12:06 PM
sry for teh panic guys....BiGg UpPs to neal thansk alot...reset it and idle is back up...the gags that get played on a newbie lolol ...now its funni
Jan 15, 2005 | 01:55 PM
glad to hear you fixed it, now do all of us a favor and learn to type THE THE THE THE THE
