please help engine making clanking noise
Old Jan 18, 2005 | 08:43 AM
ronnyblaze03's Avatar
i have a 95 maxima and i bought a 96 maxima engine with 6000 miles on it. so i took it to the shop and we swapped engines/ now it tries to turn on but theres a clanking noise where the timing chain is at. does anyone know what that is. please help. and do u know if it is necessary to put the intake manifold from ur old engine to the engine i jus put it so it can match the somputer of the car.? i was wondering if that was necessary. please help me
Old Jan 18, 2005 | 09:07 AM
Dagger969's Avatar
Check the timing chain. If its the chain its kinda pricy and a pain in the a$$. And someone else may know better here but I dont think theres a difference in stok IM's.
Old Jan 18, 2005 | 09:10 AM
Charcoal95GXE's Avatar
where are the 6000 miles 96 motors hiding?
Old Jan 18, 2005 | 11:45 AM
6000 mile engines
Toms 4n autoparts. www.toms4n.com 1-800 255 - 6656 ask for mik
Old Jan 20, 2005 | 06:44 AM
Stephen Max's Avatar
Probably just a worn or stuck timing chain tensioner.
Old Jan 20, 2005 | 09:18 AM
thank ya 10 chars
Old Jan 20, 2005 | 09:41 AM
oh crap thats a good site thanks again bro!!!
Old Jan 20, 2005 | 09:56 AM
ya no problem
Old Jan 20, 2005 | 10:21 AM
Dreizehn's Avatar
The tensioner will clank like that until it gets oil pressure.
Old Jan 20, 2005 | 11:04 AM
oh ok. how does it gain oil pressure? would that cause it not to start?
Old Jan 20, 2005 | 11:23 AM
Dreizehn's Avatar
The clanking noise you hear isn't related to it not starting. If the motor only has 6K on the odo, and the case has never been opened it's probably a safe bet that the chain is fine.
Once you get the car started, you will get oil pressure. I couldn't get any oil pressure out of mine just by cranking it with the starter.
You have the the whole intake installed right? The connector is in the MAF and all the others are connected? If it isn't starting it could be any number of things. You have to start ruling things out.
Are all electrical connections made?
Is the motor grounded?
Does it have spark?
Does it have fuel?
Old Jan 20, 2005 | 11:27 AM
If the chain is so loose that it jumps a tooth, that may make it hard to start, but I doubt it would make it not start at all. Maybe, though.
First things to check, though, are
1) is fuel getting to the cylinders?
2) is the right amount of fuel getting to the cylinders (i.e. not flooding)?
3) are the spark plugs firing at all?
4) are the spark plugs firing at the right time?
Old Jan 20, 2005 | 11:41 AM
Ya Everything Is Connected, It Has Fuel. How Do U Check If The Spark Plugs Are Firing?
I Might Jus Take It To The Shop To Have The Diagnostics Done
Old Jan 20, 2005 | 12:59 PM
Now When I Bought It The Guy Said I Have To Change The Intake Manifold . Put The Old One Onto The New One. He Said So The Sensors Can Match The Computer. But We Didnt Do That., U Think That That Might Be Why It Doesnt Wanna Start?
Old Jan 20, 2005 | 01:06 PM
MDeezy's Avatar
they should have the same sensors, dont think they added sensors in the 96 over the 95 and if that the case you could just swap sensors instead of taking the whole manifold off.
if you can pull the block back out again, then check the timing chain, (assuming it is) it will be much easier to fix and work on with it out of the car. Maybe I just like seeing engnies pulled. . . thats probably too much work for a timing chain
Old Jan 20, 2005 | 01:27 PM
Take one plug out at a time. Connect the coil to it, and a jumper wire from the plug threads to engine ground. Use an alligator clip to connect the jumper to the plug. The coil needs to be connected to its harness. Have someone crank the engine and look for a healthy blue spark as he cranks. You can check just one plug to see if it makes spark, or do all 6 if you want.
Hondarydr
Dec 30, 2024 06:15 PM
boomerbrian
Nov 8, 2015 05:10 PM
maxinout93
Oct 27, 2015 01:29 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
