Got an error code: Vacuum cut valve bypass valve - anyone know what it means?
Well, my check engine light came on last night, just pulled the code and it's 0801 - Vacuum cut valve bypass valve. Anyone know what this means? Daniel B Martin or anyone? I don't want to drive my car with this crap, but i have class today too. hmmm
Any help would be appreciated.
The VCVBV is a solenoid-controlled air valve. You may remove it from the vehicle and perform a bench test. There are two air hose nipples on the valve. Fasten a length of clean rubber vacuum tubing to either nipple. Gently blow through the hose. The valve should be closed and it should be difficult or impossible to send air through the valve. Now use a pair of fused test leads to provide 12 volts to the electric connector. The polarity doesn't matter. With the VCVBV solenoid energized the valve should be open and it should be easy to send air through the valve.
Originally posted by Daniel B. Martin
The possible causes of this problem include a defect with the wiring or electrical connector, or with the valve itself.
Now, should the valve itself be broken, do you think this is something that can be replaced by a mild diy-er like me or should i take it to the dealer to be done?
Thanks so much!
... Think my amp install could have triggered something? ...
Chris likes to play with HAND tools
I doubt it.
Do this yourself. It doesn't require any special tools. You will need a jack, a jackstand, and an assortment of ordinary hand tools.
I doubt it.
I doubt it.
I doubt it.
See Chilton, Figure 6, page 4-8.
Thanks again!!
...After about 2 seconds of thinking about it I realized that those hoses are air not fuel so I attempted to take the two hoses off but I could not get them off. Is there a special method of taking these vaccum hoses off?
Do the twist!
Re: Do the twist!
A stuck-tight vacuum hose can usually be persuaded to come off by grabbing the end with a pair of ordinary pliers and twisting to rotate the hose 30-45 degrees. If this doesn't work you may resort to a sharp utility knife and slit the end of the hose lengthwise. This will require you to replace the hose. This is low-pressure hose which can be bought at any auto parts store for less than $1 per foot.
magiconthetire
10-26-2015 09:03 PM
tseng1023
10-15-2015 08:30 AM
RealityCheck
10-02-2015 06:34 PM
HerpDerp1919
09-29-2015 02:02 PM
