The cost to drop 1.5"
Old Apr 26, 2001 | 05:55 PM
cbock's Avatar
Ok. I'm new to this so bare with me.
I am thinking about lowering my Max. I have 97 GXE. From what I have been able to gather here. I will need springs and struts. I've read that springs alone will more than likely cause the stock struts to wear out quickly. So springs and struts:
Where is a good place to get them and how much should I expect to pay to have them installed?
Can I do it my self?
Will a 1.5" drop require a camber kit?
I know these things have been asked before, but I haven't seen them all asked together and I can't piece it together myself.
Old Apr 26, 2001 | 06:48 PM
Sprint's Avatar
Its free if you cut the springs
ok no..
probably 500
219 for h&r's and 3xx for tokico's
no camber kit for 1.5
shox.com has them cheap..
if you want sprint sprngs 2 inch drop.. Alex at southeast autoworks sells them for 119
price will depend on where you live.. i have seen from 200 - 300 for install..
however if you have the tools its not hard to do yourself
NickStam has instructions here
because you are using Tokico if you so choose you only do 1 - 9
http://www.performanceix.com/how-to/...print_koni.asp
Old Apr 26, 2001 | 08:03 PM
teejnut's Avatar
dang thats a lot to get springs installed... a shop around where i live does it for about $75-$100
Old Apr 26, 2001 | 08:06 PM
Sprint's Avatar
springs and struts? for only $100? thats pretty good
here labor is $60 per hour..
so i am guess your place does all 4 in under an hour or they have very cheap labor rates
Old Apr 26, 2001 | 08:13 PM
teejnut's Avatar
under the table eh?
heck yeah!
Old Apr 26, 2001 | 08:15 PM
Sprint's Avatar
under the table eh?
i think they have cheap labor rates...
also... if u pay cash u dont' have to pay taxes...
Old Apr 26, 2001 | 08:43 PM
dmbrazilian's Avatar
So what do you guys think of the sprint springs? And also I was thinking of just getting the springs right now and do the struts later....any input will be appreciated..
thanx
late
ok no..
probably 500
Old Apr 26, 2001 | 08:49 PM
Sprint's Avatar
I have sprint and koni's .. hoping to install them this weekend..
thanx
late
Old Apr 26, 2001 | 09:32 PM
mzmtg's Avatar
Minister of Silly Walks
I have the Sprints and Tokicos. I like them fine. I would just save money until you can get struts too. It would just be a pain to have to go through the installation a second time later.
Old Apr 26, 2001 | 09:49 PM
dsmercado's Avatar
The price of the install will depend on where you are located. I'm in NYC and it cost me $200 to get my Eibach/Tokicos put in. I thought that was a little on the high side, but it was a place that I trusted and that I frequent a lot, so I had no problem shelling out the $$$.
Where are you located anyway?
Old Apr 27, 2001 | 06:03 AM
Hey mzmtg how is the ride with the sprints? And do you have custom rims? Cause I was thinking of also getting 18" rims, would that be a problem with the sprints?
thanx
Late
Old Apr 27, 2001 | 09:12 AM
cbock's Avatar
Yeah, I'm wondering about the ride quality myself. I've read 15-20% stiffer ride. Any comments on that?
Good point about having all the work done at once. I was thinking about just the springs. But it wouldn't make sense to go through the install process twice.
BTW, I'm in San Diego. Anyone know who and where would be a good place to go and have this done? Actually, I may try to find a friend to help me. So maybe just a good place to buy them. Also, sprints or h&rs, others? I think I want a 1.5" drop. What's the price and ride quality cost between a 1.5" and a 2" drop?
Old Apr 27, 2001 | 12:41 PM
EuroMaxima99SE's Avatar
I'm also working on doing my suspension...I'm thinking about H&R's and Tokico's or KONI's, I know Tokico's re much cheaper then Koni's but is it really worth spending more cash and getting KONI's or Tokicos work just fine???
Old Apr 27, 2001 | 12:55 PM
Sprint's Avatar
nothing beats H&R's on Ride quality.. not even Eibachs.. sprint i havn't installed them yet.. but the lower you go the more you are going to suffer (although that is not the case with H&R's i had those..they were excellent) however its cheaper to go with the Spring on the 2 inch drop than the H&R's or Eibachs
Old Apr 27, 2001 | 07:54 PM
Enduro's Avatar
SprintMax back when u had H&R which struts was it riding on? Can u make a comparision/elaborate on the difference between H&R and the stock spring in terms of ride harshness and corner lean? Oh and was your car an SE? Cause I'm wondering IF H&R is as comfy as stock SE springs then how could it help at all in cornering. Thanks!
Apr 16, 2020 05:15 AM
maxima-junky
Oct 7, 2015 06:13 PM
Noela
Sep 26, 2015 08:22 AM
2kmaximel
Sep 24, 2015 03:55 PM
