front passenger Seat bolts stripped bad.
Old Jan 24, 2005 | 01:39 AM
topdog1207's Avatar
Well the thing is i dropped my car off at my brothers house for him to hook up my system and put my amps under the passenger side seat.(Im not good at that stuff) When i got back from school, apparently, he stripped out 3 of the 4 bolts and even the part that attatched to the frame trying to get a good ground. NOw the seat isnt even secured at all. Well only 1 bolt is holding the seat down, the other 3 are just sitting in the holes. I was like WTF. SO now i was wondering if any1 else ever had this problem and if so how much would i be looking at to have this rethreaded. DO i just take it to the dealer? Im totally lost. Any help would be appreciated.
Old Jan 24, 2005 | 07:42 AM
adithius's Avatar
A bolt can be replaced. Go to home depot and tell the sales person what you need. They set you up with the right (power) tools. Bring a bolt sample.
You should get the bolts out and just get new bolts.
Old Jan 24, 2005 | 08:14 AM
ny96max's Avatar
try to find a socket that fits the stripped heads very sung and hammer it on. Then use an airgun (high torque) and get them out. Sounds ghetto but it will work. Maybe buy a single socket from sears to do the job so you dont ruin one out of a set you might own already. Once they are all out either go to Nissan or HomeDepot (prefrebly Nissan) and order up new bolts. You might also wanna consider a "tap and dye" set to re-thread the part attached to the body.
goodluck,
Ant
Old Jan 24, 2005 | 08:40 AM
Flava_24/7's Avatar
Boosted Panda
So are the threads in the holes stripped or the heads on the bolts?
Old Jan 24, 2005 | 09:15 AM
nismomax98's Avatar
i work for company that makes inserts for stripped holes, u can buy them at like napa stores they are called helicoils, get the size of the bolts and tread size pick up this helicoil kit it comes with drill tap and new insert for new tread all u have to do is drill new little bigger hole use the drill provided tap it and put new insert in it and your good if u have trouble getting them pm me
Old Jan 24, 2005 | 09:22 AM
I30tMikeD's Avatar
I did it to my passanger seat. Stripped out the bolts and the threads in the floor. I just cleaned up the bolt threads as much as possible, used a bunch of washers and cranked the bolts down as much as I could. Worked for me and the seat is not moving...but that is not a solution to use if you plan to remove your seat ever again.
Old Jan 24, 2005 | 10:53 AM
95CustomMaxima's Avatar
If the head of the bolt is stripped really bad, you can take a vise grip and clamp it as hard as you can and tap it with a hammer to loosen/remove the bolts.
-Nick
Old Jan 24, 2005 | 11:17 AM
MDeezy's Avatar
-Nick
had to do that when trying to get out oil drain plug, started to strip bad, got a vise grip, clamped that b itch on and got it loose (plus I sprayed some WD-40 first )
Old Jan 24, 2005 | 11:55 AM
topdog1207's Avatar
Its the threads to the floor/holes that are stripped. Of course the bolts are too but im not worried about that. Thats easy to fix. Its the stripped floor holes that im worried about.
Old Jan 24, 2005 | 12:38 PM
Flava_24/7's Avatar
Boosted Panda
You should be able to either do the helicoils or just get a tap and die set and rethread the holes either option is going to result in a different size bolt being used so just make sure the bolt fits through the mounting hole on the seat. Or you could simply just enlarge that hole as well. Really shouldnt be a difficult fix.
Old Jan 24, 2005 | 12:59 PM
nismomax98's Avatar
if u use the helicoils u will be able to use the same bolt if not stripped this would be the wise option u dont want to crash and ur seat going throught the window with somebody
Old Jan 24, 2005 | 11:32 PM
topdog1207's Avatar
can this just be done at the dealer?
Old Jan 25, 2005 | 12:55 AM
topdog1207's Avatar
any have a clue how much the dealer would charge to do this?
Old Jan 25, 2005 | 05:36 AM
nismomax98's Avatar
arm and leg maybe left nut 2, way too much unless u know somebody
Old Jan 25, 2005 | 05:50 AM
sterlingmaxima's Avatar
try a gator grip on it first they are so cheap to buy now these days. If you cant find a cheap one buy it and return it after your done with it.
Old Jan 25, 2005 | 10:48 AM
topdog1207's Avatar
well i dont want to give up a nut just to fix it. I guess ill call them up and find out how much. Ill let every1 know
Old Jan 25, 2005 | 10:54 AM
Wetballoon's Avatar
Might try welding in bolts frum the bottom. us a nut up top. Also makes aligning the seat a little easier next time you take it out.
carguy96
20
Feb 6, 2021 06:21 AM
Matt93SE
May 24, 2019 02:58 PM
spidgeon
Aug 24, 2015 11:14 AM
george__
Aug 18, 2015 07:06 PM
follyburr
Aug 7, 2015 09:50 PM
