Headers and Y-pipe
Old Jan 24, 2005 | 07:06 AM
NYR1199's Avatar
Headers and Y-pipe
Can someone help me with this... I found this combo on ebay and was wondering if its a good deal...check it out...
http://cgi.ebay.com/ebaymotors/ws/eB...category=33631
Old Jan 24, 2005 | 08:17 AM
Bags's Avatar
VG Ridah's Biatch Hoe
looks to good to be true....
And to replace the headers you will have to remove the motor to get to the back one
Old Jan 24, 2005 | 08:29 AM
MrEous's Avatar
^ Jeff™
You don't need to remove the motor...and this has been discussed tons of times already.
It is NOT worth the $$ to get the headers.
You will ONLY see about 3whp from headers. The ypipe alone is what you want.
Old Jan 24, 2005 | 08:50 AM
Bags's Avatar
I'd like to know how to remove the rear exhaust manifold without taking out the motor.
Old Jan 24, 2005 | 08:57 AM
MrEous's Avatar
^ Jeff™
Take the intake manifold off.
Remove crossmember (remember to support engine)
It is a tight fit but you can do it. We installed my headers without taking the crossmember off but I've heard it's alot easier to do by taking it off.
Took us about 8hrs to do...including lunch.
Old Jan 24, 2005 | 09:49 AM
maxspeed96CT's Avatar
The original VQ...
i remeber back in the day everyone wanted headers and it was the next big thing.
Now that they make them, no one cares
Old Jan 24, 2005 | 10:04 AM
MrEous's Avatar
^ Jeff™
Yeah, unfortunately when people see that there were only about 3whp gains from adding the headers you kinda lose some of the pizazz.
Old Jan 24, 2005 | 11:35 AM
Bags's Avatar
I bet it was.. I have looked at it twice and the only time I ever was willing to touch it was when the engine was out.
I knew the cross member had to come out, just not sure if you could get to the bolts holding it on.
The heat shield looks like it can come off fairly easily.
Old Jan 24, 2005 | 12:02 PM
MrEous's Avatar
^ Jeff™
The heat shield was a BISH to get off...we ended up severely bending mine to get it out. You won't be able to get all bolts from the same side/angle. It also makes it easier to reach everything with the hood off.
Bags-Are you getting headers?
Old Jan 24, 2005 | 12:08 PM
I30tMikeD's Avatar
I got the rear headers off with only having the intake manifold removed. One of the header bolts and the EGR is real tricky to do but it is possible
**edit** but this was removing the cattman headers w/o the heatshield and installing the stock w/o the heat shield.
Quickywd01
Sep 21, 2016 09:36 PM
Socalstillen
Sep 26, 2015 12:01 PM
lrb6805
Sep 17, 2015 04:49 PM
Violator
Sep 9, 2015 10:14 AM
