01-04
Old Jan 26, 2005 | 09:56 PM
maximaintheface's Avatar
01-04
just got that code, my speedomator doesnt work somtimes, it cuts out, when i tap the gauges it liek cathes and works again, is there somthing loose in there that could be causeing the code? or is that a differt part
Old Jan 26, 2005 | 10:16 PM
s0ber's Avatar
Whats 0104??
Did u replace your guages with aftermarket guages??
Old Jan 26, 2005 | 10:25 PM
Akumachan's Avatar
I never narc'd on nobody.
s0ber, 0104 is vehicle speed sensor, and since its the vehicle speed sensor, and youre gauges sometimes dont work.... well, i hope i need not say much more, just replace it.
Old Jan 27, 2005 | 01:07 PM
the sensor or the whole cluster. i dont even know where the sensor is ill look it up in the book. how much is it for a new sensor if u can buy it seperate
Old Jan 27, 2005 | 01:13 PM
SlackR237's Avatar
Rollin' on 'Caps
I have 0104 code right now and have for a while. You just need to replace the sensor when this code shows up. The speed sensor is located *on top* of the transmission transaxle, if you're using Haynes, the picture doesn't help much cuz you have no sense of what you're looking at or where you're looking.
If you take your intake off (note: don't take intake MANIFOLD off, that would be a beatch...) up to the throttle body, then look down and look/feel around the top of the transaxle, you should see the top of it, it's back there a little bit.
They're not too expensive, about $30 from the stealership.
Old Jan 27, 2005 | 01:42 PM
SlackR237's Avatar
Rollin' on 'Caps
I was feeling ambitious, so here's a zoom shot of the vehicle speed sensor location. The 3rd picture isn't too great, but I thought I'd throw it in anyway...
Good luck
Old Jan 27, 2005 | 05:46 PM
dude thats gay
Old Jan 27, 2005 | 10:40 PM
are u sure its not somthing thats just loose or somthing, when i push in the tripomator or w/e its called , the mph gauge works again, its like somthing is loose or somthing in the gauges. cuase everytime i push in the trip button even a little bit it starts to work again
Old Jan 28, 2005 | 12:07 AM
DAVE Sz's Avatar
Hooooooonda.....
I get 0104 once in a while. The 0104 is caused when the speed sensor tells the ECU your speed is at 0mph even though you're moving. If I'm not mistaken, the connector on the right of the front O2 sensor connector located in front of the engine behind the radiator, is the vehicle speed sensor. Just follow the bottom part of the connector to the transmission case, I'm not sure if SLACK is showing the same part but it doesn't seem like it. Both the connector and cable, and the sensor itself are the same on the manual and auto maxima. If you follow the cable it will end up on the side of the transfacing the driver's side wheel. It's a $20-$30 part and a very easy DIY job. Make sure to raise the car on the driver's side as some trans fluid may come out
Old Jan 28, 2005 | 12:45 PM
ya im just gunna change the part out
vq4thgen4life
Jan 22, 2014 06:07 PM
kaseman94
Dec 24, 2010 04:14 PM
ImportCarPartsP
Nov 28, 2008 01:14 PM
xnyc
Mar 18, 2008 10:11 PM
