Do you think the max is reliable in general?
in general YES the max is very reliable......but in return it is only as reliable as the previous own let it be.........obviously he didnt take care of the maintnence he said he did and treated it like ****........but fix all the little things and u will love it and never want to get rid of it
i didn't bother to read other posts,, but my idea and opinion is that certain cars are MADE better .. i.e. not plasitc radiators and what not.. the difference between a civic and a accord. a maxi and a sentra, altima.. it doesn't lie... price n cost..
Originally Posted by KCMaxima98
Maybe Im expecting too much. This 98 is the newest car I have ever owned (I own a 99 toyota but my wife drives it). My previous cars were all over 100K miles and more than ten years old when I bought them. I thought that getting a newer (for me that is) Nissan would save me money in repairs. And my wifes 99 Camry has not had one single thing go out on it and it has the same miles on it. So I thought the max would be comparable to that car as far as repairs go.
I bought a 98 GXE about 6 months ago. It currently has only 87K miles and I have had lots of problems with it so far. The guy I bought it from claimed that nothing ever went wrong with it while he had it
. Maybe it just doesn't like me or something. Here is a short list of everything that I have had to replace so far that is not brake pads, lights, general maintenance.
Knock sensor (if this is so common why doesn't Nissan own up to it?)
Alternator (Didn't check if it was under the recall before I replaced it but I doubt it is)
EVAP system vent control valve (set off a CEL and made my exhaust stink)
Rear main seal is seeping oil.
AC/Heat fan only works on speed 4 (I saw good info. in the FAQs on this)
CV boots are cracked.
Trunk doesn't really want to open anymore.
When you hit the gas hard in 5th gear the car shudders and acts like it is going to stall. RPMS don't seem to jump so Im guessing it isn't the clutch...yet.
This may not seem like much to some of you who have owned your cars for years but remember this all happened within six months or so. Every time I fix something a week later something else goes wrong. I expected a better product from Nissan I guess.
. Maybe it just doesn't like me or something. Here is a short list of everything that I have had to replace so far that is not brake pads, lights, general maintenance.Knock sensor (if this is so common why doesn't Nissan own up to it?)
i got a 98se 5-speed with 220k and here is the list of things that were replaced
trany as soon as car was off waranty =)
clutch recently (at about 215!; the disk was still good, but release bearing fell apart in 5 pieces right inside)
tie rod ends(recently)
ball joints(at 150)
rear bearings(about 170)
rad fans (200)
and the car needs O2 sensor
so i would say that's pretty reliable
the only thing i am not happy about is the quality of paint
ball joints(at 150)
rad fans (200)
My max is my baby. I have had 0 issues since the day I put the first mile on her. Boosted at 6,500 miles and at a 106,800 now and have not replaced any parts or had any failures. There are a few small things going to need replaced like the alternator, the starter, ks, but that is to be expected. I think I have been real lucky but I also take extra good care of my max too.
Originally Posted by Frank Fontaine
I would say the Maxima is pretty reliable esp. for the original owner. The problem is that the original owner had to make numerous trips back to the Nissan dealer to get stuff fixed under the 3 yr/36, and then some more things with the 5 yr/60. That was really annoying. But once done, it's fine. My car is at 103k now.
It sounds like the one the poster got probably never got any of the stuff fixed. That's gonna add up to a lot of coyne at the dealer now unfortunately. EVAP is an expensive job, and it fails in the mid 50's usually. It's more than just an idiot light being on--it causes progressively worse hot starts, to the point where in the summer the car doesn't want to start after running and excessively cranks. Over $400 at the dealership to fix.
Originally Posted by mzmtg
I spoke too soon
My car died on the side of the road on my way to lunch. I have no idea why...
I have fixed most of this stuff. The EVAP vent control valve was only 130.00 with labor at the stealership. I replaced the KS, alternator ect. I haven't messed with the rear main seal yet because it is just seeping. It doesn't leave puddles of oil yet. My weird problem with the hesitation in fifth gear is a phantom issue right now so I don't know what to fix yet. I plan to fix the resistor on the heat/ac fan sometime soon. Dont get me wrong. The car is running fine now but it has already put a sizeable dent in my wallet in six months. I just want the bleeding to stop.
For $130 they didn't replace the boost sensor, because that lists for 151.56. But it's ok because they charge 1 hour labor for it so if you needed it, the labor you already paid wouldn't have included it (I hate paying twice for the same labor). The valve assy is 40.46 and the canister is 46.46--sounds like you got both of those replaced plus 1 hour labor.
I bought my 97 Maxima from a dealer when it had 82k on it. It now has 175k on it. It has always started, even in 0 degree weather. It has performed very well. With this...all cars require maintenance and general upkeep...and as cars age...parts tend to wear out and quit. In general, I have found the life span of Nissan parts to be quite reliable and made to last a long time. Most of my maintenance and repairs have been preventive...belts, hoses, pads, gaskets, cv boots etc.
Unlike FORD (fix or repair daily)...Nissans have a proven long term track record of reliability. I really do not understand domestic car manufacturers and the junk they produce. Sadly, I have owned two fords which only proved to be rolling money pits of constant repairs. My Maxima was a welcome change.
Its reliable as in it will drive fine everyday, but all the crap that needs maintanance is really draining my wallet. I failed my emissions test by a lot. I have Cattman headers full cat back, high flow cat, and cai. I needed a tune up cuz the last one was 2 years ago. I also started burning oil pretty badly. Last oil change only a quart came out! I switched to synthetic, and the problems seems to have gone away.
Rust is starting to eat through the radiator mount bracket, and I had to replace both front brake calipers cuz the insides froze and wouldn't clamp. My rotors were done too.
Suspension was shot so i replaced all that too.
You tell me if the car is reliable. I know I can rely on my bank to keep track of all the money I spent.
I bought mine in 99 with 40k. (1996 maxima)
Also bought extended warranty till 100k hehe (now at 135k)
-Had replaced tranny (5spd at 55k or 80k can't really remember)
-1st clutch at 100k, 2nd installing saturday (fidanza + exedy stage I)
-left ball joint
-heated seats went out two years ago (never fixed them)
-Bose went out last year (bought one off Ebay, didn't work
Pretty reliable, especially the way I drive.
BUT THE WORST thing about it...
IS THE PAINT!
-left ball joint
)Pretty reliable, especially the way I drive.
IS THE PAINT!
-Had replaced tranny under warranty (5spd at 55k or 80k can't really remember)
-left ball joint
IS THE PAINT!
-left ball joint
IS THE PAINT!
Yes, the Maxima is exceptionally reliable!!! I have over 18 years of Maxima ownership (all 4th gen) without having any non maintenance problems at all. I believe in preventive maintenance and use Amsoil products whenever I can. I keep my cars in impeccable condition so I am not driving junk!
the only things ive had to replace were fornt bank 02 . still need knock sensor . and i changed the starter they were very very easy fixes. ive had the car since 90 k i have 139000 right now and still runs like new
yes I would rank the max right under the camry we have two in the family both from diff generations and boy are they solid cars no major matinence run great. toyota really did a great job I have to give them that but not the most styling cars. That is were teh max kicks *** it is a hot car.
-left ball joint
IS THE PAINT!
-left ball joint
IS THE PAINT!
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
mkaresh
Mar 12, 2018 06:48 PM
maxima297
Sep 30, 2015 03:32 PM
