how do you get these things off?!?!
Old Apr 27, 2001 | 06:29 PM
phatmax95's Avatar
hey how do you get off the cover to the speakers on the back of a 98? i tryed to get them off put i ddint wanna break anything, do you have to go through the trunk or what.. someone write back quickly.. thanks
Old Apr 27, 2001 | 06:51 PM
mzmtg's Avatar
Minister of Silly Walks
You have to take out the whole back seat.
Remove the bottom cushion by undoing the two latches under the front edge
Remove four 10mm bolts from the upper cushion, two at the very outer lower edges and two under the trim when you fold down the arm rest
Then lift the upper cushion off its hooks and out of the car
Then you have to remove the side trim, the big pieces that the seat belts poke out of on the C-pillars, just pop them off carefully
Then carefully pop off the rear deck trim...the grilles are attatched to it
There...simple
Old Apr 27, 2001 | 07:28 PM
Phil02E46's Avatar
for more indepth.. i think performanceIX has it in their "how to" section. check it out www.performanceix.com
D Mason
Jun 21, 2016 04:43 AM
doctorpullit
Mar 29, 2016 11:08 AM
bigfrank
Oct 1, 2015 12:51 PM
09maxshawn11
Sep 30, 2015 10:28 AM
