Installed 01 Tranny In 95 Now No Speedo
Old Jan 30, 2005 | 01:43 PM
maximagx5's Avatar
Just Got Finished Putting In A 01 Tranny In My 95 Max And Now I Cant Get The Speedometer To Work I See Where The Vss Is But I Dont See No Wires That Lead To It. Is There A Different Harness That Has To Be Purchased To Make This Work Please Help If Anyone Knows. The Only Thing I Noticed Is That My Backup Switch Had A Different Harness On It That Was Cut From The Junkyard That I Brought It From But I Just Replaced It With New One
Old Jan 30, 2005 | 02:52 PM
VeeQueue's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
You can reuse everything off your old tranny because everything will plug right into the 5th gen tranny (speedometer pinion gear, neutral position switch). My donor tranny's speedometer pinion gear was burnt beyond recognition so I had to use my original anyway. Just replace the donor one with your old one.
Old Jan 31, 2005 | 10:23 AM
maximagx5's Avatar
I WILL TRY IT AND SEE IF IT WORKS
Old Jan 31, 2005 | 10:58 AM
krzymax's Avatar
Maxima owner since 2000
where do you guys get your donor cars? i'm looking to do a 5-speed conversion
Old Jan 31, 2005 | 11:02 AM
VeeQueue's Avatar
I found my tranny and other **** on car-part.com
Old Jan 31, 2005 | 11:52 AM
gtr_rider's Avatar
192.168.1.1
damn youre still around
Old Jan 31, 2005 | 03:59 PM
Mishmosh's Avatar
Yeah, what VQ said. YOur old speed sensor can be inserted in the new tranny without a problem. The 01 tranny I got didn't even have a speed sensor, but instead it had a port cover which I removed and stuck in the old one.
Old Jan 31, 2005 | 04:01 PM
lilaclucymaxima's Avatar
Team Ramrod
do you know of any page with a write-up on how to put in a 2001 tranny in a 4th gen? what parts other than the actually transmission do you need?
Old Jan 31, 2005 | 04:23 PM
Mishmosh's Avatar
Other than the aforementioned vehicle speed sensor, you don't need anything....straight bolt on.
Old Jan 31, 2005 | 05:10 PM
joosdawg's Avatar
somone tell me im right or wrong does the 01 tranny have differnt ratios then the 95-99's?
Old Jan 31, 2005 | 05:14 PM
Team Ramrod
your right
Old Jan 31, 2005 | 05:18 PM
joosdawg's Avatar
better gearing im assuming? at least i do know the 3rd gear is fixed compared to the 4th gen 3rd gear death...maybe ill just swap the 01 tranny with valvebody then and gain a few tenths in the QM
Old Jan 31, 2005 | 05:57 PM
joosdawg's Avatar
well i went to car-part.com and found an 01 AE tranny with locking differnential and 40K in my own state for $750! thats pretty good i think, is that all ill need? if i get the locking diff and i dont have that do i need any differnt parts? and if it helps in drivability then why dont more 95-99ers do this?
Old Jan 31, 2005 | 06:02 PM
Team Ramrod
is the driveability that much better? does the car feel that much faster?
Old Jan 31, 2005 | 06:09 PM
Mishmosh's Avatar
It doesn't help with driveability unless you mean that the "feel" of the gearbox is sooooo much nicer. If you get a locking 01 AE tranny, you will need to get the driver's side axle. Congrats on finding that...they are REALLY hard to come by.
Old Jan 31, 2005 | 06:16 PM
VeeQueue's Avatar
Your 5th gen tranny didn't come with a speed sensor? Dont all 4th/5th gen trannies use the speedometer pinion gear to read speed? Did the cover look like a factory piece?
Old Jan 31, 2005 | 06:27 PM
Team Ramrod
what exactly does a non-locking differential and a locking differential mean?
Old Jan 31, 2005 | 06:31 PM
joosdawg's Avatar
wow nvr been to car-part.com now i see a whole 00vi setup for a total of $380 with upper&lowerintake mani TB and fuel rails! also "good shape" black leather heated 1 power seat for $110 in my city!?
Old Jan 31, 2005 | 07:32 PM
Mishmosh's Avatar
Yeah. it's weird. The port cover is definitely factory. I just thought that maybe 01's didn't have the speed sensor in that location (read from somewhere else?) but others had sensors with theirs.
Old Jan 31, 2005 | 08:52 PM
Broaner's Avatar
2060lbs and falling...
For reference this is a pic of my '01 AE. As you can see the speed sensor is to the right of the gearbox and below the axle input.
Old Mar 28, 2005 | 10:53 PM
Broaner's Avatar
I totally forgot about this thread. I finally got everything running and went for a drive. I have no speedo or ODO. I've been searching. Do I need to get a 4th gen gear sensor/speed sensor? BTW, my reverse lights work.
Old Mar 29, 2005 | 06:21 AM
nismology's Avatar
Originally Posted by enjoyincubus504
your right
No. He's wrong. The gear ratios are the same from 95-01.
MR2 T'd
Jul 9, 2021 05:06 AM
mvm062
Nov 30, 2020 09:00 AM
pktaske
May 6, 2016 07:49 AM
pktaske
Sep 4, 2015 08:40 AM
Lowered_a33
Sep 1, 2015 07:49 PM
