What sensors are these?
Old Jan 30, 2005 | 06:04 PM
motocross416's Avatar
Can anyone tell me what sensors these are?
I am trying to get a starting problem figured out on the 97 Maxima. So far, it is not the battery, starter, crank position sensor on the side of the motor. I was told one of these is the other crankshaft position sensor, but I'm not too sure. The sensor behind the pulley is just bolted on the side, it doesn't go into the engine at all. I haven't taken the other sensor out because I'm not sure if oil will come out if I pull it out or not. The sensor in the top pic is facing toward the front of the engine. Thats the best pic I could get of it.
Old Jan 30, 2005 | 08:48 PM
maxS
1st - low oil pressure light
2nd - crankshaft position sensor - REF
Old Jan 31, 2005 | 06:41 AM
cool, thanks for the reply
Old Jan 31, 2005 | 03:49 PM
JDM_Maxima's Avatar
sensors
the crank sensor that will give you hard starting problems is on the transmission. if that sensor is not giving your computer the right info, you will get a check engine light and hard starting.
the crack sensor by the oil pan in the pic detects misfires
Old Jan 31, 2005 | 07:26 PM
Could you post a picture of the one on the transmission? I don't know where that one is at.
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
