need help starting problem
Old Jan 30, 2005 | 06:25 PM
staytuned24's Avatar
hey my car cranks over but doesn't start up i went through 4 starters ,a coolant sensor , crank position sensor both of them and a sub harnest. I'ts really bad when its like 20 degres or colder. but if someone pushes me and i pop the clutch it starts up.
Old Feb 1, 2005 | 11:26 AM
cyjad's Avatar
how's the battery? Try hooking up a battery charger and boosting it and then try to start it while boosting.
Old Feb 1, 2005 | 05:50 PM
tried all that i think i'm going to take it to the dealer
Old Feb 3, 2005 | 08:48 PM
brock3j's Avatar
if you figure it out post it up I might be able to use the help
Old Feb 3, 2005 | 09:20 PM
OneToughMax's Avatar
have you checked your ignition switch? probe all the wires in the harness during the crank. you may not be getting power to ignition, accessory, second accessory, starter, or second starter. the ignition wires are all soldered to the ignition switch, and if one is shorted, solder joint is cracked, etc. it will do that. here are the wires to look at if you don't know already:
there is a molex plug under there - the wires change colors through the plug.
ignition: blk/wht - blk/red
starter blk/yel - blk/wht
second starter: grn/blk - red/blu
accessory: red/yel - red
second accessory: blu - wht/blu
use a dmm and probe all the wires. it's worth a shot.. HTH
dan
matts95max
Apr 23, 2025 10:44 AM
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
trungg86
Sep 4, 2015 04:58 AM
dcardello
Sep 3, 2015 11:44 PM
