Hey There Need Quick Question on Rims
Old Apr 28, 2001 | 05:45 AM
BrianV's Avatar
Hey guys, Maxima's have a 5x114 (5x114.3) pattern right?
Old Apr 28, 2001 | 08:17 AM
Daniel B. Martin's Avatar
Right. However, the large center hole diameter is also important. You will find wheels which have 5x114.3mm (5x4.5") but won't fit your Maxima.
Old Apr 28, 2001 | 10:16 PM
BrianV's Avatar
Daniel B that didn't make exact sense, the last part. The won't fit your maxima. Can you please clarify.
Thanks you da best.
Old Apr 29, 2001 | 01:30 AM
capmaxima99's Avatar
For instance my rims are 18x7.5 with a 5x114.3 and a 45 offset. But the back rims didnt fit on due to the hub being bigger than the center of the rim. So I was told to just mill it down a little bit. But i didnt want to do anything like that. So all I did was buy a 5 mm spacer and the rear rims are perfect. Couldnt get any happier.
Chris
Old Apr 29, 2001 | 09:04 AM
Big center hole diameter is important
Thanks you da best.
You might get some Honda wheels which have the 5x4.5" wheel stud pattern. You think "Okay, these will fit my Maxima." When you try to install the Honda wheels they just won't fit. The reason is the big center hole in the Honda wheels is too small to fit on the Maxima hub. This has nothing to do with wheel offset.
Jcof88
Sep 9, 2015 03:11 PM
soloist3
29
Sep 1, 2015 03:47 PM
adamgalazka
Aug 31, 2015 05:55 PM
classymax420
Aug 6, 2015 06:35 PM
Jcof88
Aug 3, 2015 10:43 PM
