Dropping It, what else do i need ..
Old Feb 1, 2005 | 11:15 AM
96white's Avatar
I am going to be dropping the max on maxspeed springs and kyb Gr-2's and i want to know what else i should be replacing since have everything apart, and what i should look for to replace while everything is apart.
I have a 97 GXE 5spd, 113, xxx miles.
Old Feb 1, 2005 | 11:21 AM
Kevlo911's Avatar
Kevlo for President
Front strut mounts(OEM) - 30 bucks each
KYB Strut Boots from www.taylorautomotive.com SB103/108 - 2 of each.
Regrease the bearings when you take it apart.
Old Feb 1, 2005 | 11:35 AM
96white's Avatar
Do i have to get the "KYB Strut Boots from www.taylorautomotive.com SB103/108 - 2 of each."
I work for a stealership and get a big discount on stock parts. Can i just use stock boots?
Old Feb 1, 2005 | 11:36 AM
Kevlo911's Avatar
Kevlo for President
No, you will have to cut htem to make them work, not worth it.
Since you work there, just get new bearings, the part number is in the Modification FAQ's.
Old Feb 1, 2005 | 11:38 AM
96white's Avatar
what will new bearings do for me ?
Also, I BlueC did the same setup and used stock boots, and it worked just fine.
Does anyone else have an opinion on if i will fine using stock parts.
thanks
Old Feb 1, 2005 | 12:00 PM
Kevlo911's Avatar
Kevlo for President
Okay, if you want to use the stock ones, do so. I am just telling you what you "should" do, but its not my car.
Part Number: 54325-5V000
Description: BRG STRUT MTG
List Price: $19.98
http://216.109.117.135/search/cache?...icp=1&.intl=us
Mar 12, 2020 12:06 AM
jonreidhead
Jan 6, 2016 09:38 AM
Turbonut
46
Oct 21, 2015 08:28 PM
maxima-junky
Oct 7, 2015 06:13 PM
Redfox
Sep 28, 2015 10:41 AM
