Headlight Fuse keeps blowing
Old Feb 1, 2005 | 09:28 PM
NyC97Max's Avatar
im jus wondering, if the headlight fuse (RH) keeps blowing, what might be the cause of that? i have a 8k mcculloch HID kit wired as the plug-n-play setup with no wiring harness. Recently my right side HID went out, and i immediately assumed it was the ballast, but then when i replaced it with a stock 9004 bulb, that bulb didnt light up either, and instead it kept blowing the fuse. I have no idea why this is possibly happening, can anyone help me out. thanks.
Old Feb 3, 2005 | 01:35 AM
Maximathug's Avatar
Check to see if the system is grounded, also I noticed that a few hid kits are improperly wired they have a jumper wire conected between the hi/low terminals. So if you high beam some one you will blow your fuses. Unless you have a hi/low hid kit your losing you high beams. Hopefully this will solve your problem.
Old Feb 3, 2005 | 05:05 AM
njmaxseltd's Avatar
The HID setup on the right side might be faulty.
Old Feb 3, 2005 | 07:58 AM
NyC97Max's Avatar
i actually figured out the problem before i read the replies, the wires werent grounded and seecured properly and were causing a short. thanks for the help anyhow.
tarun900
19
Dec 20, 2021 06:57 PM
doctorpullit
Oct 28, 2019 10:58 PM
leatherneck
Sep 30, 2015 09:16 PM
Noela
Sep 26, 2015 08:22 AM
