LED Question
Old Feb 3, 2005 | 07:22 AM
Dagger969's Avatar
LED Question
Hey im installing some new blue LEDs in the dash and other places....Will using the dimmer for the dash LEDs screw them up?
Old Feb 3, 2005 | 08:16 AM
nismomax98's Avatar
not if u do it right
Old Feb 3, 2005 | 08:25 AM
MAXRB8's Avatar
use each LED with a 470 ohm resistor rating at 1/2 watt and you should be fine
Old Feb 3, 2005 | 08:43 AM
Dagger969's Avatar
Yeah. I bought a resistor for each LED, thanks
Old Feb 3, 2005 | 09:00 AM
pavelsmax's Avatar
you should be fine i've dimmed my dash leds on occasion and its never hurt them
Old Feb 3, 2005 | 02:10 PM
cam_honestiam's Avatar
You can (if you want) buy a potentiometer at any eletrical parts store. This is what your dimmer switch is. You can get various ratings; even some that, when turned all the way up, will not burn your LED's--all without adding additional resistors to the LEDs themselves because the potentiometer is, in essence, a variable resistor. This is what your "dimmer" and "volume" buttons are: potentiometers. All you would do is connect one leg of the potentiometer to a constant 12V, and the other(s) to the LED.
Old Feb 3, 2005 | 02:37 PM
ManualMaxima's Avatar
5th Gen till she dies!
yeai have all of ine hooked up to the dimmer and i have no problems at all.
chisam14
Nov 6, 2018 08:56 PM
Fbana41
Aug 29, 2016 12:18 PM
Unclejunebug
Apr 2, 2016 05:42 AM
worldwiderecognized
Sep 24, 2015 06:56 PM
