Bent Rear Beam?
Old Feb 3, 2005 | 04:39 PM
96ItaliaSE's Avatar
il massimi bassi
Bent Rear Beam?
Hi
i have maxima I purchased from the org on tien S springs. I took it to a body shop to be aligned as was told the rear beam was damaged and the toe and camber would continue to slip. He said the springs were the cause and If i planned on fixing it would pretty much have to back the money truck up to the garage to get it fixed. .....and put it back to stock....suggestions???
btw Is this thing safe to drive locally?
Old Feb 3, 2005 | 04:41 PM
Jeff92se's Avatar
I'm needing a caw
Could be if the car had been damaged before. Or maybe some bushings are worn? Worst case, if the shop knows what they are doing, they should be able to put the car on the rack and gently bend the beam back. Or worst case, just replace the beam. Can't be that hard.
matts95max
Apr 23, 2025 10:44 AM
Maxima.KsA
May 15, 2020 04:14 PM
alahjahwan09
18
Sep 21, 2015 09:12 PM
Hdnseek
Sep 9, 2015 05:55 AM
dcam0326
Sep 8, 2015 11:02 PM
