part1 es bushing install...
Old Feb 4, 2005 | 09:10 PM
1FSTMAX's Avatar
So tonight after work I decided to tackle down all my front end ES bushings. This evening I removed all the sway bar bushings, disconnected the seteering tie rods from the steering knuckle, removed my calipers, caliper bracket, and rotors. Tomorrow I need to remove or move aside my half shafts, and remove the steering knuckle, and take out the lower control arm. Once that's done and installed back on, I have to install my es motor mounts. I should be able to finish this tomorrow afternoon. The next weekend I have to take out my beam, to install the bushings on those. Well i'd thought id share my progress..
Old Feb 4, 2005 | 09:39 PM
ThurzNite's Avatar
where are you getting your mounts pressed? how much? Good luck dood!
Jae
Old Feb 5, 2005 | 04:32 PM
1FSTMAX's Avatar
my pops pressed them in at his work..
All front end bushings complete.. Next week gonna put in the rear trailing arm ones..
Old Feb 6, 2005 | 08:47 AM
RA030726's Avatar
I'm nutty for Nissans
sounds like fun
Old Feb 9, 2005 | 12:58 PM
VQuick's Avatar
Chassis Freak
Wait, I thought Energy Suspension only made rear trailing arm bushings for the 5th gen? Or did you just buy those since the 5th gen rear is so similar to ours?
I've got my front sway bar bushings installed, nothing else yet.
Old Feb 9, 2005 | 03:14 PM
1FSTMAX's Avatar
they should be the same.. ill find out on saturday if they fit or not.
Old Feb 9, 2005 | 03:28 PM
VQuick's Avatar
Chassis Freak
Awesome, post back here when you find out. If they do fit, I'll be happy but I'll also be p!ssed at ES for saying they were 2000-2003 only!
Old Feb 9, 2005 | 04:12 PM
1FSTMAX's Avatar
i'll post some info when im done..
I must say installing these es bushings has really tied up my front end. It doesn't feel sloppy like before. There's no lag when i turn into a corner. I'm loving it. I'm sure it will be better when i get my Tein ss coilovers with edfc!
Starrider
Dec 18, 2015 04:43 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
ColdCananda
Sep 20, 2015 10:45 PM
