Clutch Noise
Old Feb 5, 2005 | 12:27 PM
afroken's Avatar
Clutch Noise
Hey guys, Im new to the forum but not to nissan. Anyhow, lately ive been getting this really bad grinding noise when i engage the clutch (its new by the way), even in neutral. sounds almost like a baseball card in a bicycle tire. i was wondering if anyone else has ever experienced this before?
thanks
1998 SE 5spd
Old Feb 5, 2005 | 12:45 PM
Luigi38's Avatar
hey man, since we can't hear neither see your car. How about u be more specific as to where the sound's coming from? tranny?
Old Feb 5, 2005 | 01:35 PM
afroken's Avatar
yea, its from the tranny. and it can be heard as long as the clutch is engaged.
Old Feb 5, 2005 | 04:24 PM
JDM_Maxima's Avatar
thanks
1998 SE 5spd
was the reason why you replaced the clutch because you where hearing some nosie and it didnt go away? have you release bearing and trans checked out. hopefully its nothing in the trans, like syncros or bearings. good luck
Old Feb 7, 2005 | 08:59 PM
afroken's Avatar
no, it was just time to change the clutch. it sounds almost like there is no lubrication somewhere. i was thinking it might be a tranny/clutch bearing because it makes the noise if the car is in neutral and i take my foot off the clutch. thanks again guys.
Old Feb 7, 2005 | 11:10 PM
maximagunner's Avatar
did you fill the tranny back up.
Old Feb 8, 2005 | 01:31 AM
afroken's Avatar
im sorry, i havent been clear. the clutch was changed 45k ago, the noise is a recent occurance.
Old Feb 15, 2005 | 06:19 PM
afroken's Avatar
hey guys, i found the culprit. the throw out bearing is bad. $600 in labor for a $30 part. if anyone knows of a place in the houston area that would give a better price please pass the info. thanks
Old Feb 15, 2005 | 07:38 PM
dawalkster's Avatar
is craving Bojangles
my throw out bearing is also shot. ive learned to live with it though, unless someone could tell me how to replace it myself.
Old Feb 15, 2005 | 09:11 PM
alpicone's Avatar
To change the TO bearing you have to pull the tranny. It is basically the sam job as replacing the clutch, so if your clutch isnt relatively new it might be worth replacing that at the same time.
Maybe you can find s/o on the org that would do it for you for cheaper. To pull the tranny for someone who knows how to do it shouldn't take that long.
Too bad you're so far away from brooklyn. I would do it for you for much less.
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
