Interesting Date And Calculations
Old Apr 29, 2001 | 02:47 AM
BrianV's Avatar
I've had one of those car calculators for a while now, and I decided to search around the board and figure out roughly how much power my Maxima was making. I found all the people who had the same mods as me, or at least very similar and came up with: 175 WHP, and 194 WHP to be common power for a 5spd.
I took that into consideration and added 20% for drivetrain loss (common front wheel drive percentage is 18-22%). I lowered my car the adequate amount and changed coef of drag from .320 to .300 (lowering = less drag). I also made the peak horsepower and peak torque come in a little later; breathing mods make this happen. The base curb weight for a 5spd Maxima SE is 3030. Now I have power seats, a box, and a 140 lbs driver. I made it 3,200 which might be a bit too light still, but here's the data anyways:
¦+----------------------------------------------------------------------------+_
¦¦ EDIT/ANALYZE ¦ CAR TITLE: NISSAN MAXIMA SE - BRIAN ¦_
¦+---------------ENGINE----------------++--------------CHASSIS & BODY---------+_
¦¦ Disp: 2988 cc. Loc:FRONT Type:NORM ¦¦ Car test weight: 3200 lb. ¦_
¦¦ Horsepower: 210 bhp @ 5700 rpm ¦¦ % weight on front wheels: 62 % ¦_
¦¦ Torque: 228 lb-ft @ 4400 rpm ¦¦ Wheelbase: 106.3 in. ¦_
¦¦ Comp Ratio:10.0:1 Redline: 6500 rpm ¦¦ Tire section width: 225 mm. ¦_
¦¦ Start rpm: 1600 with Clutch: DUMP ¦¦ Tire circumf. (opt.): 6.21 ft. ¦_
¦+-------------------------------------+¦ Wheel diameter: 16.0 in. ¦_
¦+-------------DRIVETRAIN--------------+¦ Tire profile: 55 % ¦_
¦¦ Transmission: 5 speed MANUAL ¦¦ Coefficient of drag: 0.300 ¦_
¦¦ Gear Ratios 1st: 3.29:1 4th: 0.95:1 ¦¦ Frontal area (opt.): sq.ft.¦_
¦¦ 2nd: 1.85:1 5th: 0.80:1 ¦¦ Overall height: 53.0 in. ¦_
¦¦ 3rd: 1.27:1 6th: :1 ¦¦ Overall width: 69.9 in. ¦_
¦¦ Final drive ratio: 3.82:1 ¦¦ Ground clearance: 3.5 in. ¦_
¦¦ Driving wheels: FRONT ¦+-------------------------------------+_
¦+-------------------------------------+________________________________________
__________________________________________________ ______________________________
Results:
Sorry the results are blurry, I had to get it under 50K.
Anyways, I think it's relatively accurate, but I know the top speed is higher because a stock 95 tested 144, and I've had mine well passed 140, like closer to where 150 would be (even though error is present that high). The first time at the track at Pomona I ran a 14.9, second time I ran a 14.7 (extremely cold that day, fresh oil change). So all in all it seems quite accurate. It has a database of small cars and almost everyone is right on the money.
Stock results for a 1995 Nissan Maxima SE 5spd:
Stock results for a 1995 Nissan Maxima SE Auto:
Well I'm bored and thought someone would find this interesting.
Old Apr 29, 2001 | 07:37 AM
dwapenyi's Avatar
Cool stuff! 2 questions.
1. What does the 175 WHP and 194 WHP refer to?? I know the abbrev. is wheel HP, but what's the difference between the 2 numbers?? Auto compared to manual?
2. Where'd you get this car calculator from??
DW
Old Apr 29, 2001 | 11:06 AM
BrianV's Avatar
Oops I meant to say 175 WHP and 194 WTQ
James92SE
142
Jan 2, 2024 09:23 AM
mkaresh
Mar 12, 2018 06:48 PM
King_Ten_Ahead
Sep 27, 2015 02:24 PM
lux97Max
Sep 11, 2015 01:12 PM
