Is It The Clutch?
Old Feb 5, 2005 | 04:52 PM
jorgie_maxima98's Avatar
Is It The Clutch?
hey its chris, i am about to make a 4000 mile road trip in a couple weeks from tampa, fl to tacoma/seattle, wa going from I-10 all the way across and I-5 all the way up. anyways, my clutch when i put it in like 1st or 2nd gear, it hops once or twice and sometimes when i get to 3K rpms it will slow down until i hit the gas hard and then will pick up. is it the clutch or have i messed something up? could it just be that i need to flush the tranny fluid because the car sat for a year when i was in iraq? give me some pointers of what i need to do or if you know what it could be.
thanks,
chris
Old Feb 6, 2005 | 07:24 AM
maximabebe's Avatar
Does NOT sound like a clutch issue. I would reccommend cleaning out the throttle body and doing a swap on tranny fluid and change your regular oil if you are preparing to drive 4000 mi. Double check your brake fluid / clutch fluid / power steering juice...etc......
maximabebe's Avatar
Also, check your ECU for codes (FAQ'S) Could be an infamous knock sensor issue.
Old Feb 6, 2005 | 08:04 AM
Guinader's Avatar
yeah when yhe mentioned the 3k rpm I thought the same thing...
Old Feb 6, 2005 | 08:40 AM
mansurxk's Avatar
when my clutch was on its way out, it bogged for me at 3000 RPM, it would go up and down then eventually accelerate, i thought it was the plugs. then i thought i twas the intake cone being dirty. then i swapped out the coil packs. then it wound up being the clutch. im still not that clear on his symptoms.
Old Feb 6, 2005 | 03:30 PM
thanks
thanks guys, i am going to do the tranny flush and i did the oil and spark plugs already and if nothing happens, i will do the whole clutch thing, where is a good clutch place online, i drive my car kinda hard so i need a good clutch, i just put the exedy in a year and a half ago but it sat for a year so that could have been the problem
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
