HELP! highbeam indicator stays on no matter what
I have a strong feeling this is a relay related issue. My highbeam indicator stays on now no matter what (regardless of stalk setting and whether or not the car is on/off). Now it is quite a task to even get the headlights to work (I have to flip the headlight stalk on/off, high/low before I can get only 1 headlamp to work). I looked at fuses #53 and #54 and they are fine. Can anyone prescribe a cure?
Im thinking there is definitely a short. I installed HID's and used the low-beam power and ground wires to connect directly to the hid ballast. The highbeam power wire was simply terminated with a piece of electrical tape. I am thinking water might have got in and caused a short circuit?
The left side headlight comes on only.
no offense but you should really specify by drivers or passenger side, left and right people dont really understand somtimes
Originally Posted by joosdawg
no offense but you should really specify by drivers or passenger side, left and right people dont really understand somtimesBy left side i mean only the passenger side light comes on.
OK I went through all the wiring/bulbs and nothing seems to be wrong. I even switched the ballasts and everything, checked the fuses and the highbeam light still remains on. The only time it comes off is if I remove the fuse for the drivers side headlight. Does anyone know if this can be due to a faulty switch?
Originally Posted by mansurxk
someone in the for sale section is selling a light stalk for like $10 shipped, look into that, as well as a relay.
Yup I already PM'ed him. I wonder how hard it is to replace a light stalk?
jmlee44
Oct 2, 2022 02:13 PM
mkaresh
Mar 12, 2018 06:48 PM
