Stuck in Overdrive, wont turn off, any ideas.
Old Apr 29, 2001 | 02:35 PM
duplex's Avatar
I press the button over and over, and nothing happens. The car just stays in overdrive. If i hold the button down, it turns off till i let go. I think somethign got messed up. Has this happened to anyone else, if so, how do I fix it?? unscrew the shift and check?
thanks
Old Apr 29, 2001 | 06:12 PM
duplex's Avatar
thanks
anyone know?
Old Apr 29, 2001 | 08:13 PM
mrdeucie
I'm not sure how to fix your problem and I really don't turn my overdrive off ever, but isn't it okay for you to leave your overdrive on?
Old Apr 29, 2001 | 08:53 PM
duplex's Avatar
No cause, then it wastes gas by not going into 4th gear!
Old Apr 30, 2001 | 03:14 PM
mrdeucie
I thought it wasted less gas when the overdrive was on.
Old Apr 30, 2001 | 04:54 PM
max808's Avatar
thanks
Sounds like you have a bad connection in the switch controlling the overdrive. It may just need some cleaning off of some dust or something is no letting the switch engage and stay off.
Old Apr 30, 2001 | 06:11 PM
1997 Maxima SE's Avatar
What? I thought the light turns on saying overdrive off meaning 4th is locked out... overdrive on means you have 4 gears... off 3???
Old Apr 30, 2001 | 06:14 PM
duplex's Avatar
thats right, when it says OD off it locks out 4th, basicly, which sucks, cause im riding around 70 mph at 3500 - 4000 rpm haha
Old Apr 30, 2001 | 07:03 PM
Daniel B. Martin's Avatar
Low cost repair ideas
thanks
Idea #1) Spray Frog Juice (WD-40 or equivalent) into the O/D button. It's amazing how many things can be fixed with Frog Juice.
Idea #2) Yank the plastic trim which surrounds the shifter. Locate the two-wire cable which comes out of the base of the shifter. Follow that cable to the nearest connector (just a few inches). Disconnect the connector. Your O/D will be ON forever. That's not a bad thing.
Old Apr 30, 2001 | 07:22 PM
duplex's Avatar
thanks, will try
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
