{Compression testing} How do I connect a remote starter switch?
Old Apr 30, 2001 | 11:41 AM
emax02's Avatar
I figured everything out to test my engines compression except for connecting a remote starter switch. Well how do I go about doing this? Thanks
BTW I found the instructions, they were kinda hidden also I read the section in my Chilton's manual.
Old Apr 30, 2001 | 12:52 PM
MardiGrasMax's Avatar
I just used the key to crank it. My cheep compression tester holds the pressure so I can see it when I get back under the hood.
Old Apr 30, 2001 | 07:29 PM
Daniel B. Martin's Avatar
The starter motor has two wires connected to it, one thick and one thin. Disconnect the thin wire. Connect one lead of the remote starter switch to that starter motor terminal, in place of the thin wire. Connect the other lead of the remote starter switch to the starter motor terminal which has the thick wire.
jsmith24
Feb 1, 2016 12:35 AM
mikeg75
Nov 30, 2015 05:12 PM
Excalibur23
Oct 13, 2015 04:33 PM
msellas
Sep 23, 2015 09:16 PM
rnb754
Sep 14, 2015 11:39 PM
