Can't Get Rear Caliper Piston IN!! HELP ASAP!
Old Feb 7, 2005 | 04:10 PM
sean05's Avatar
hey guys,
well im replacing the pads for my rear brakes. I got the old pads off and put the new ones on but i can get the caliper back over because the piston is pushed out to far. I read in my serivice manaul that you have to twist it clockwise. Well ive been twisting and it doesnt seem to be moving. Its moving very very very very slowly! Has anyone ever had this problem or have a solution? PLEASE HELP in going insane!
Old Feb 7, 2005 | 04:27 PM
Pappa Grande's Avatar
I have a car with high miles. I had a really tough time turning the rear calipers, but I finally did it. You may have a frozen caliper. If so you need a new one. You may just have an old one like me. Keep at it. It is imperative if you have a tough turning caliper that you are using a caliper tool to turn the piston. Many on the forum will tell you using pliars is enough. That is not my experience with old rear calipers...
Old Feb 7, 2005 | 04:38 PM
nitromax's Avatar
the right tool will allow you to apply pressure while turning. pushing in while turning is needed to get the piston in. get the cheap/inexpensive cube caliper tool from autozone or advance auto. that, a 3/8" ratchet and 6" extension should get you there.
Old Feb 7, 2005 | 04:44 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
there is a thread about this near the bottom of the front page....
Old Feb 7, 2005 | 04:52 PM
MaximaSE96's Avatar
Maxima Owner
i have 193k on mine and i had no problems
Old Feb 7, 2005 | 06:40 PM
chuckie311's Avatar
all you need is a pair of pliers and some muscle its not that hard.. unless the are frozen then go buy some new ones
Old Feb 7, 2005 | 06:46 PM
bullfrog's Avatar
a few days ago: http://forums.maxima.org/showthread.php?t=376762
I describe how to do it in there.
matts95max
Apr 23, 2025 10:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
6spd4dsc
Mar 4, 2016 05:19 PM
ef9
Sep 5, 2015 11:18 PM
