Led Mod Problem
Old Feb 8, 2005 | 06:25 PM
joeeey's Avatar
Led Mod Problem
Last weekend I moded all of my dash light with 5000 mcd Blue LED's. The switches look fine but the cluster has high and low lighting spots. I thnik I'm gonna add some more LED's. Has anyone had this problem??
CHECK IT OUT
I need some advise. Thanks
Old Feb 8, 2005 | 06:35 PM
G4nismo's Avatar
yeh more should resolve it or led bulbs off of superbrightleds. oh, u have a 99, that means ur's is #74 i think, which sucks compared to 194s.
Old Feb 8, 2005 | 06:41 PM
big_al's Avatar
Ya, I got the 5 bulb LED and returned them for the single inverted LED. Its not the brightest but they don't leave hot spots.
Old Feb 8, 2005 | 06:43 PM
superblack99's Avatar
do the 74 bulbs only come with a single led
Old Feb 8, 2005 | 06:54 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
you either got to put more under there or fill up the rest with a wide angeles LED 194 bulb that screws into the back of the cluster. same thing happened to me when i did mine. i put 8 leds under the speedo and still had some low spots. regular LEDs like that really only emmit light strait forwars, not arround.
Old Feb 8, 2005 | 07:16 PM
illmortal's Avatar
I did my LEDs in my gauges and in the hazards/defrost and so far both hazards and defrost blew out slowly... went from bright blue to dark blue.. to green then finally shut off pretty ****ty since I used 100ohm resistors when 80ohm resistors were recommended.
Old Feb 8, 2005 | 07:39 PM
overseaz's Avatar
I have the sonic glow kit and i love it.
That Doesnt look bad though, not bad.. youll get it figured out.
Try the wide angled LED's...
Id have done something like that myself but i wanted a contrast.. white face with blue needles.
http://www.geocities.com/kwikiewit/P0004809.jpg
Old Feb 8, 2005 | 08:07 PM
rome06's Avatar
so for a 97' u wud have to use the #194 bulbs and those are the ones that just screw in the back to the cluster right...no soldering or anything right??
Old Feb 8, 2005 | 11:00 PM
Vlasic's Avatar
actually, dont the 97-99 clusters use a different bulb? i think only the 95-96 ones had the 194 bulbs.
Old Feb 9, 2005 | 06:52 AM
illmortal's Avatar
How exactly did you do that with your needles?... Mine glow out of the needle area and the gauges look blue as well.. Not only that the Odometer is impossible to get an LED under the needle... there's this clear plastic that's in the way and if it wasn't in the way it would be the only place I can stick the LED into without disturbing the motor and its parts. That's exactly what I tried to do but like I said it's not as clean looking as yours.
Old Feb 9, 2005 | 08:41 AM
Wisdoms97's Avatar
i have a 97, i just did my cluster all up in red. the 97 uses 194 bulbs, theres 5 of them. defintiely have to watch out for those hot spots tho. im actually about to try regular 194's and see how that goes. ill post soon as i get that done. if anyone comes up with another solution tho please share
Old Feb 9, 2005 | 08:45 AM
illmortal's Avatar
I have a 97 and I use 194 bulbs...
Old Feb 9, 2005 | 09:10 AM
Vlasic's Avatar
my mistake. i thought i remember reading on a write up somewhere that you have to use a dremel to make the 194 bulbs fit the cluster.
Old Feb 9, 2005 | 10:16 AM
rome06's Avatar
u didnt have to solder anything right??? the bulb jus fits inside the plastic piece that twists into the back of the cluster right?
Old Feb 9, 2005 | 10:19 AM
Wisdoms97's Avatar
yes the 194s are a direct fit
Old Feb 9, 2005 | 03:59 PM
illmortal's Avatar
Well the thing about the LEDs... you gotta get them with the specs showing that they are 194 Wedge LEDs, if they're plain LEDs you're gonna have to solder them or some how wedge the poles to the 194 sockets with the 194 bulbs in em as well...
Old Feb 9, 2005 | 06:45 PM
rome06's Avatar
where wud i buy them with the specs that shows that they are 194 bulbs
Old Feb 9, 2005 | 06:52 PM
Vlasic's Avatar
you can get them here: http://www.autolumination.com/
Old Feb 9, 2005 | 08:19 PM
rome06's Avatar
fukkkk 5 bucks a bulb?? thats expensive
Old Feb 10, 2005 | 08:57 PM
joew's Avatar
i want to do my red. can you post some pics.
MAXSE5SPD
Sep 17, 2022 04:00 AM
ballerchris510
Sep 23, 2015 08:46 PM
Maxima Pride '07
Sep 12, 2015 07:29 AM
minsbang
Sep 11, 2015 08:48 PM
mpbclutch33
Sep 8, 2015 06:21 PM
