5spd
Old Feb 10, 2005 | 01:38 AM
ogparjay's Avatar
5spd
this is just for future reference, is there a place for ~2000 that does a 5spd conversion around southern california and how long is the procedure? Anyone?
Old Feb 10, 2005 | 02:54 PM
chuckie311's Avatar
you can try stu`s tansmission in long beach
here is there info
Stu's A E Transmission -5531 Cherry Ave, Long Beach, 90805 - (562) 428-4641
Old Feb 10, 2005 | 03:02 PM
vsamoylov
u want to drive to norcal and my bor and i could do it. we usually charge $1500-$1700 parts and labor. check a thread about a parts car that i am going to pick up in the for sale forum for 4th gens. let me know.
Old Feb 10, 2005 | 11:39 PM
ogparjay's Avatar
thanks for the info, i'll keep this in mind.
Old Feb 10, 2005 | 11:41 PM
vsamoylov
no problem man.
Old Feb 11, 2005 | 08:30 AM
TJ_Max's Avatar
Paradox Systems Vendor
my friend did his for 700 labor, and he just needed the parts.....someone told me 800, i just need to get the parts....how much do the "parts" cost? all u need is manual tranny right?
Old Feb 11, 2005 | 10:30 AM
Crockpot's Avatar
Parts Needed:
5 Speed Transmission (try and get the I30 LSD or Canadian Maxima LSD if possible – doubt it)
Both Manual drive shafts (if you have ABS you need specific ones, if you don't have ABS you can use ABS ones)
1 clutch kit (clutch disc, pressure plate, throw out bearing)
2 shifting rods (support rod + control rod) (acquire used w/ all the hardware)
Return spring (connect to the 2 shifting rods (Buy this new, the stiffer the tighter your shifter feels)
1 shifter (Acquire used to get nuts and bolts (buy with the shifter rods)
1 shifter console piece (interior)
1 shift consul bracket (Replaces your auto one) (interior) (dealer name plate bolt and transaxle hole cover)
1 brake pedal
1 clutch pedal
1 master cylinder
Hydraulic lines for clutch
1 slave cylinder for clutch
1 extra set of transmission harnesses (might come w/ 5spd transmission)
1 18ga wire and wiretaps
Assorted cotter pin set.
1 Manual Fly wheel
1 Manual motor mount
Transmission Fluid (GL-4 or redline is preferable)
Locking pin and clip for the clutch pedal to the master cylinder (you could bend a nail but I would go to the dealer and pay $4)
2 nuts that fit the threads on the clutch pedal.
1 bolt that bolts in the top of the clutch pedal (the dealer can find it's size for you)
1 bolt that connects the control rod to the transmission (the dealer can find it's size for you)
1 Haynes Manual just in case you need extra help
read how-to's on it
Old Feb 11, 2005 | 01:15 PM
TJ_Max's Avatar
i printed it, thanks, my shopping list, but whats the total cost for all this?
Old Feb 11, 2005 | 06:09 PM
vsamoylov
look to spend around $700 for al lthe pars and then labor all also.
ef9
Oct 4, 2015 08:43 AM
220k+ A32
Sep 11, 2015 02:18 AM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
ef9
Aug 27, 2015 10:17 AM
