60,000 mile tuneup??
Old Feb 12, 2005 | 04:44 PM
One Crazy Max's Avatar
hey whats up. my car is nearing the 60k mark and i was wondering what needs to be done for the 60k mile tuneup.
Old Feb 12, 2005 | 04:54 PM
MDeezy's Avatar
they have a list in the faqs but.
Tire Balance/Rotate
Oil/filter Change
New sparks
coolant flush
tranny flush
top off fluids
clean TB, IACV
believe that is all.
you lucky low milage bastard
Old Feb 12, 2005 | 05:39 PM
Bobo's Avatar
Excuse my ignorance, but what is an IACV? Is it different than the PCV?
Old Feb 12, 2005 | 05:41 PM
tomservo291's Avatar
Idle Air Control Valve
It's located on the manifold, easy to clean.
Old Feb 12, 2005 | 05:52 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
Tire Balance/Rotate
Oil/filter Change
New sparks
coolant flush
tranny flush
top off fluids
clean TB, IACV
ontop of that, clean/replace PCV, clean EGR. replace fuel filter with 300zx filter.
yes IAC is different fomr the PCV. its a plate behind hte manifold/TB. there is a write up and i think some pictures in the how-to section. PCV you wer better off just replacing, its so cheap anyways.
Old Feb 13, 2005 | 09:26 AM
Bobo's Avatar
What are the benefits of replacing a 4th Gen fuel filter with a 300ZX filter?
Old Feb 13, 2005 | 09:35 AM
Bobo's Avatar
Also is there anything diagnostic in nature that would require going to a stealership? I trust they hook the car up to a computer - what do they do: adjust idle if necessary, air/fuel mixture etc. What about doing everything else and just taking it to the stealership for this purpose as well as any visual checks they do? Is it necessary to change the 2 belts ato 60,000 miles or should they last longer than this: alternator belt, air conditioner/compressor ?
Old Feb 13, 2005 | 09:38 AM
mansurxk's Avatar
no advantage except your time. itll last twice as long and costs teh same amount. if you have an abs system, then id only want to do that thing once cuz its a PITA
Old Feb 13, 2005 | 11:08 AM
adithius's Avatar
The stealership just charges you more b/c you think your getting the best service. Not always true.
You can check your own ECU. Check the stickys. The Idle is not an issue if you idle around 650RPM.
The belts dont need to be changed unless they are worn. Check to see if there are any cracks or rips.
Old Feb 13, 2005 | 11:33 AM
Bobo's Avatar
Thanks, yes I do have ABS. The car presently idles perfectly and I've never cleaned the TB, IACV, replaced PCV, nada - only the fuel filter once and have K&N air filter which is relatively new. Recently flushed rad and replaced transaxle fluid so I'm going to leave well enough alone for awhile I guess. The car runs like the day I bought it.
Turbonut
46
Oct 21, 2015 08:28 PM
JoshG
51
Sep 21, 2015 10:41 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
Socalstillen
Sep 20, 2015 11:46 PM
hntwhttail
Sep 12, 2015 03:43 PM
